N/A B18C1 Build
Old 06-05-2005, 12:02 AM
  #26
DC2point0's Avatar
Default Re: (JH4DC4-2GSR)
Haha i like how you're building the motor in your room I thought about doing the same..but dont want my room to be full of oil
Old 06-05-2005, 08:13 AM
  #27
Yambor's Avatar
Default Re: (DC2point0)
Its really not that bad honestly, I just leave my windows open!
But anywho. im deciding on LMA choices since i will be going with a cam of higher than 10.8mm of lift, that being, the skunk2 stage2's. For some reason they say only the late model LMA's are like that of the ITR, yet i pulled them out of my 95 gsr head and they are the same as say the 1997 which is the same as the itr. so therefore i do not think i have to change the lma's since the lma's on this 95gsr head have a bigger pad area so the tit on the rocker arm cannot slide off and create valve train bind.
Old 06-05-2005, 02:45 PM
  #28
philafelman's Avatar
yeah, i was wonderin about that because my 95 gsr head looked like it had the larger pads, so i was confused as to whether i should have changed it...i didnt though, so ill cross my fingers.
Old 06-05-2005, 02:56 PM
  #29
Yambor's Avatar
Default Re: (philafelman)
Yep, turns out im lucky, here a quote from MD off of TI:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MD &raquo;</TD></TR><TR><TD CLASS="quote">you lucked out then. As long as you don't have the b16a smaller tapered LMA, you're ok.
95 is a weird model year because in 1995 Jan-June it was OBD1 but in the summer some of the production OBD2a stuff showed up like these LMA's and by Sept 1995 you had the model year 1996 and OBD2a officially starting.
the OBD2 GSR's apparently according to Rocket has these larger LMA's..</TD></TR></TABLE>
So there goes $240 i can spend elsewhere!
Old 06-05-2005, 06:21 PM
  #30
EGmmBAH's Avatar
Default Re: N/A B18C1 Build (JH4DC4-2GSR)
gansta *** room.
Old 06-13-2005, 02:04 PM
  #31
Yambor's Avatar
Default Re: N/A B18C1 Build (EGmmBAH)
UPDATE: 6/13/05
Well guys after almost 2 weeks i finally received my AEBS Head Studs, and i also purchased 10 OEM Honda Oil Filters and 30 crush washers from a member on TI for $35 so i couldnt pass up the deal..
The head is at the machine shop, it as been milled .005 and hot tanked, i also received new valve guides from honda too. All thats left for the head is cams and valves.
This paycheck on friday will put me near another 1g to dump into the motor. So hopefully this will be done well before planned....
I will post pics of the head studs installed tonight... in the meantime, im gonna go eat this 16oz steak and potatoes...
Old 06-13-2005, 04:41 PM
  #32
haha, looks like someone in the honda parts dept. needed a lil $$$.
Old 06-13-2005, 07:37 PM
  #33
Yambor's Avatar
Default Re: N/A B18C1 Build (philafelman)
Head Studs Installed:
Old 06-14-2005, 04:30 AM
  #34
I'm a Jackass
k24a4kid's Avatar
hey i did my motor in my room too.. but it was interesting takin it dowm the stairs since i live on the second floor..... nice build by the way.. hope everything works out and runs strong
Old 06-23-2005, 03:04 PM
  #35
Wesb18DB8's Avatar
Default Re: N/A B18C1 Build Rotating Assy. Complete w/Pics (JH4DC4-2GSR)
Yes..very nice build..i knew i shoulda went with OS pistons..oh well maybe on my next build...keep up the good work man...i bet it'll run 13's with no problem...just make sure you get some good bolt ons....what kind of intake are u going with?.. You should checkout the top fuel intake..it's the original J's, but it's still only $229
Modified by Wesb18DB8 at 8:50 PM 6/23/2005
Old 06-30-2005, 09:30 PM
  #36
Yambor's Avatar
UPDATE: 6/30/05
I received my Supertech Valves today and i must say they look great. I will post pics sometime tomarrow, I also weighed the valves. There some differences, such as the cut stems, etc...
I also today ordered the Blox IM, Hondata IM Gasket, and Spoon 2-Layer HG..
Seems to be moving along nicely now.
I am dropping the Valves, Valve Guides, seals & Skunk2 springs to the shop tomarrow and the head should be done soon.. It has already been milled .003" and hot tanked.. So next week i should have my head back, and the parts i ordered.
I might not be purchasing much here soon, because insurance and a recent ticket..
Old 07-01-2005, 06:38 AM
  #37
Lil Corb's Avatar
sounds like it's almost done. Good build
Old 07-01-2005, 06:50 AM
  #38
ne3ek's Avatar
Default Re: (Lil Corb)
ya man i was thinking about doing it in my room as well but i live in a 3rd flr apmnt so i dropped the idea pretty quick
Nice build bro, how much did you spend on those honda bearings and did you get em at a local dealership or did you order them online?
Old 07-01-2005, 07:58 AM
  #39
Yambor's Avatar
Default Re: (ne3ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ne3ek &raquo;</TD></TR><TR><TD CLASS="quote">ya man i was thinking about doing it in my room as well but i live in a 3rd flr apmnt so i dropped the idea pretty quick
Nice build bro, how much did you spend on those honda bearings and did you get em at a local dealership or did you order them online? </TD></TR></TABLE>
I got the bearings from online honda stores. Such as hondaautomotiveparts and acuraparts24/7... 8.88 A bearing i think...
Old 07-01-2005, 10:59 AM
  #40
Yambor's Avatar
Figured id post some pics to let you guys see the differences between stock gsr intake valves vs. Supertech IN valves..
Old 07-10-2005, 08:06 PM
  #41
Yambor's Avatar
UPDATE: 7/7/05
Today i received my BLOX IM, when my sister woke up up (long day at work), then i opened the door and my BLOX IM was being held by the FedEx woman, i was like this is a badass dream, but when she was like sign here and gave it to me, i was like ahha, this is real..
But anywho, the quality of this is just like that of the skunk2, i think blox cleaned their shiat up better.. Also, this did include instructions, i dont know if any other previous times they didnt, but they did this time.
I did some measurements tonight:
Inlet 64.01mm
Runner width, measured 1/8" inside of runner: 52.24mm
I will start putting the stock sensors on here soon, or i might go back to sleep..
Pics will be up tomorrow, too lasy right now..
Also, the head couldnt get done this week, even if it was, i would not have had the money to get it done.
Spoon HG should be here tomorrow, along with me ordering some skunk2 cam gears from a member on TI
Peace
Old 07-16-2005, 09:50 PM
  #42
95BG33PGSR's Avatar
dude your build is almost exactly the same as mine, you'll be happy, it's going to pull hard as hell, keep it up!
Old 07-17-2005, 01:31 AM
  #43
Viorent Grip! EG's Avatar
Default Re: (95BG33PGSR)
your build seems like its coming along very nicely
i have a comprable build to yours...i'm loving the power it made...
with you the best of luck....you'll love it once its done!!
Old 07-17-2005, 07:10 AM
  #44
RACEPAK's Avatar
Default Re: (Viorent Grip! EG)
bump for a sweeeeet indoors projekt !!!1!!
Old 07-17-2005, 04:44 PM
  #45
Yambor's Avatar
Default Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">bump for a sweeeeet indoors projekt !!!1!! </TD></TR></TABLE>
thanks man!
yea it is moving along nicely, Yet ive been doing other things with the teg as of lately
Old 07-17-2005, 09:29 PM
  #46
JDM.too.expensive's Avatar
motor is hella tight, quick question, whered u learn everything from? i started gettin into workin on the car myself but im nowhere near u...
Old 07-18-2005, 06:05 AM
  #47
bulori's Avatar
excellent , i have almost the same things, get a BDL 68-66 TB.
Old 07-18-2005, 02:06 PM
  #48
Yambor's Avatar
Default Re: (JDM.too.expensive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.too.expensive &raquo;</TD></TR><TR><TD CLASS="quote">motor is hella tight, quick question, whered u learn everything from? i started gettin into workin on the car myself but im nowhere near u...</TD></TR></TABLE>
Well my dad insipres me alot.. I constantly read articles, write ups and research all i can..
Also i work in a shop full time, that helps a little..
I have done everything to my car myself, its not that hard with the know how and right tools..
thanks for the replies.
as for the TB. thats a tapered bore, but what is BDL?
thanks
Old 07-19-2005, 01:45 PM
  #49
B-twentyVTEC's Avatar
bump for this guy!
Old 07-19-2005, 02:42 PM
  #50
EK Josh's Avatar
Default Re: (Mr_WETTY)
Real nice thread man
Quick Reply: N/A B18C1 Build
