How DO I fix A Warped Cylinder Head ??
Old 08-25-2005, 07:01 PM
310BHPB16's Avatar
Default How DO I fix A Warped Cylinder Head ??
hello guys i just took the head off my motor so as to change the Headgasket.
and when i checked the cylinder head it seemed warped in the middle as there was a dip when i place a ruler across it !!
how can i ensure that the head is flat ???
will this be a big problem if i just put the head back on ???
if i sand the high area's so they match the low ones...should it be ok ???
what paper is best to use ??
any other advice please
Old 08-25-2005, 07:15 PM
projectTeG's Avatar
take it to a machine shop and see if its servicable
Old 08-25-2005, 07:55 PM
ATS_Antone's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">take it to a machine shop and see if its servicable</TD></TR></TABLE>
Old 08-25-2005, 08:47 PM
mgags7's Avatar
put in in the oven, wait until its hot, and then bend it....
if its that bad it may be beyond the reaches of head milling....
Old 08-25-2005, 08:54 PM
xEnderx's Avatar
Default Re: (mgags7)
Millign can fix it, but you will also need to figure out how that is goign to affect CR and piston to valve clearence at TDC. If there it is REALLY REALLY warped then I would suggest jsut gettign a new head.
Old 08-26-2005, 06:17 AM
310BHPB16's Avatar
Default Re: (antone)
its not warped very much maybe a 2 mm
ok i read if i use a service plate and abrasive paper of 400 (waterproof silicon carbide and i placed paper of the surface plate and rub against the gasketed surface ...if the warping is not too bad it would be ok.
i will check the surface again with a better instrument
if i get the head machined will it have a higer compressio ratio
and will i need to use cam gears to bribg it back into timing range ???
Old 08-26-2005, 09:17 AM
MOTOCOMPO's Avatar
Default Re: (310BHPB16)
2mm is HUGE. like everyone said, take it to a machine shop and see what they say. if it's really 2mm, most likely it's not fixable.
and if you did resurface it, the cam journals could be off aligned causing the cam to lock up.
Modified by MOTOCOMPO at 10:43 PM 8/27/2005
Old 08-26-2005, 04:08 PM
Rocket's Avatar
Default Re: (MOTOCOMPO)
MotoCompo
Do cams like to run in a bent cam tunnel?
Something to Think About
Does milling the bottom the head fix this?
Old 08-26-2005, 07:59 PM
Honda Sport's Avatar
Default Re: (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Millign can fix it, but you will also need to figure out how that is goign to affect CR and piston to valve clearence at TDC. If there it is REALLY REALLY warped then I would suggest jsut gettign a new head.</TD></TR></TABLE>
also cam timing will be off.
Natural Aspirations
04-07-2013 07:11 PM
brodyl05
03-12-2007 09:56 PM
MotorSpecies ver1.6
02-09-2007 04:52 AM
saver
11
06-18-2006 09:42 PM
310BHPB16
14
08-26-2005 12:04 PM
Quick Reply: How DO I fix A Warped Cylinder Head ??
