How to build a "reliable" lsvtec/b20vtec
Old 05-02-2015, 05:56 PM
  #2126
sethg's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec
Originally Posted by TheShodan
No, you don't need arp studs
You can risk running on a stock eco as long as you want to risk it.But I would get it tuned with aftermarket management, regardless of how little you plan to "rev".
So what ecu should I go with obd2 p72 or ?
Old 05-02-2015, 06:00 PM
  #2127
Moderator
TheShodan's Avatar
You cannot tune on any obd2 ecu. That's what I was trying to tell you. If you want to risk running a stock p28 ecu, fine. But it's a risk of seriously damaging your engine.
The p72 (either OBD1 or OBD2) is best used if using a gs-r intake manifold, no other reason.
Old 05-02-2015, 06:02 PM
  #2128
sethg's Avatar
Thanks I think now I can go on the right direction
Old 12-02-2015, 12:50 PM
  #2129
Hybrid Teg's Avatar
Can i run a water and oil pump from a b16a2 on my b20v build ?
Old 12-02-2015, 09:10 PM
  #2130
93egSLEEPER's Avatar
yes
Old 12-02-2015, 10:31 PM
  #2131
raverx3m's Avatar
you would need obd2 lower timing belt cover since b16a2 has crank fluctuation sensor on the oil pump
or run any obd1 oil pump
it depends on which cover you have
Old 12-05-2015, 06:29 AM
  #2132
Bubbagump's Avatar
Almost 10 years later this thread is still goin.. Hands down best 1 on here
Old 12-10-2015, 04:44 PM
  #2133
existanzcivicb20's Avatar
any links to where i can actually see the images from the original write up?
Old 12-10-2015, 05:33 PM
  #2134
raverx3m's Avatar
probably not. HT wouldn't host them. I tried to bring this up like 4 times in the past since everyone keeps linking to those old threads. when they are useless without pictures.
it would help if they at least hosted images for these informational threads that have good write-ups and are linked to by almost everyone.
or create a file server off site to store the images for write up threads
Old 12-21-2015, 10:23 AM
  #2135
kp
kp's Avatar
It appears that the same thread was posted here: How to build a "reliable" lsvtec/b20vtec | HondaSwap
The pictures are small, but they help.
Old 05-06-2016, 06:58 AM
  #2136
Voodooboy520's Avatar
Attached PDF with pictures in case the images go down again
Old 05-06-2016, 07:05 AM
  #2137
jryKC's Avatar
Thanks!
Old 07-11-2016, 12:50 PM
  #2138
Couchwarrior's Avatar
What's up guys, I just have a quick question regarding the block assembly. I hope some of you will be able help me out. Also please don't be an a** and if this is the wrong place to ask then direct me to an appropriate place/thread.
Here's my issue. I'm building Lsvtec and this thread is excellent. I have just about everything and I'm ready to start building. Only question I have is this, on my A1 block i have a hole that seems to be not plugged. I'm positive it's just one of the oil channels considering the fact it's right above the oil filter location. Anyways I notice on some pictures when you look up on google it's plugged and on others it's not. I'm curious to whether you need this plug and if you do what's it called and what can you use to plug it because my block did not come with one. Thank you guys, and I have tried searching but to be honest I'm clueless to where to start.
Old 07-13-2016, 05:20 AM
  #2139
I like the tuna here
DumpdEJ6's Avatar
That is the Oil Orifice Control Plug, or "oil restrictor plug". You DO want to include it in the block or your VTEC head will not have correct oil pressure.
Old 07-13-2016, 09:46 AM
  #2140
Thank you sir
Old 10-31-2016, 05:31 PM
  #2141
Lombaed0's Avatar
I just got my block back from the machine shop from being sleeved. they gave me 4 dowel pins that came out of it 2 which line the transmission and block up, but the other 2 I have no idea where they go. Also how do you get them back in they don't just slide in do I have to press them in or what?
Old 11-01-2016, 04:30 AM
  #2142
DumpdEJ6's Avatar
There are two dowel pins that go from the block to the head...look at the head bolt openings near the corners on the block, their openings should be slightly larger to allow the dowel pins to slide in.
Old 11-01-2016, 05:07 AM
  #2143
Lombaed0's Avatar
ya i know there are the 2 for the head and block to line up and then 2 for the transmission and block. i dont see what else would need dowel pin as they are used to line parts up. but i came back with just the block and 4 dowel pins.
Old 01-10-2017, 02:12 AM
  #2144
xlusiveracer's Avatar
Recently got a b20v and been trying to clean it up.right now it's having some idle issues especially after warm up.1st thing is it's throwing a code 43 so I'm going to change out my sensors once I figure out what type I need.i have tried to bleed coolant,checked iacv,injectors and hose leaks.once it's warmed up I'll be coming to a stop and put it in neutral once I do that rpms would jump and down till to a complete stop and sometimes stay at steady idle 900-1100 other times it's constant 1-2k rpm up and down..any help please
Old 01-12-2017, 03:58 PM
  #2145
ryanplayjoint's Avatar
Bought a used type r trans from the dude , bam bam, that authored this write up a couple years ago. Super chill down to earth guy.
Old 02-28-2017, 10:32 PM
  #2146
Schettig's Avatar
What do I do with the pcv valve!?!??
Old 10-08-2018, 07:28 AM
  #2147
henryking7242's Avatar
goat thread
Old 07-29-2021, 12:33 AM
  #2148
Hondalover97's Avatar
What was the power on the tune afterward?
Old 07-29-2021, 03:46 AM
  #2149
BoRiCuA's Avatar
Run a catch can, better off.
Old 03-12-2022, 07:07 PM
  #2150
Westonthe's Avatar
I have a b20z2 with a b16a2 head just wondering which fuel filter i should get, the one for the car it is on (96 civic hatch) or if I need to get one that fits for a b20/b16 please lmk thanks
Quick Reply: How to build a "reliable" lsvtec/b20vtec
