Engine jerks at low RPM
I recently have this problem that when I am at low rpm's and stepping on gas the engine jerks a little bit. This problem started about 2 weeks ago when it started to rain. My usually driving habit is shifting at low rpm's below 3000. When I shift to 1st gear and step on the gas the engine jerks a little. Same thing happens when I shift to 2nd and 3rd at low rpm. This also happens when I down shift at lower speeds and step on the gas. It feels like the engine is having a hard time accelerating when I step on the gas. Awhile ago I tried doing a burn out/quick take off but the engine won't respond, it is too slow. There is no CEL.
My car is a manual 99 civic lx recently swapped with a 00 b12a2 in July. Mileage is 95k and I have not done a major tune up yet. Could this be a timing issue? Also, sometimes my idle is above 1000 rpm and sometimes it is below 1000 rpm.
Thanks
UPDATE:
Spark plugs was causing the problem. Car is running and pulling normal now.
Thanks
UPDATE:
Re: Engine jerks at low RPM
check voltage at the tps sensor. make sure you get a nice linear sweep from closed throttle to wide open throttle. About .5 volt a idle to 4.5 volts/ WOT...
Gotta love hondas and their ability to go forever with little to no maintenance.
All Motor Mentor
1 Post
If it's the harmonic balancer causing it you have big troubles ahead... I usually found that if the air fuel was a little lean in areas, it would cause that to happen.
ok I think it the TPS. I bought a multimeter and did some search on how to measure the volt but Im not getting any reading. I might be doing it wrong. I might just buy a new tps and take it to a shop.
Just an update. Problem is fixed.
I went to a shop and they said it was not the TPS. It was the ignition coil and the spark plugs needs to be replaced.
I replaced the ignition coil and it did not fix it.
I replaced the spark plugs and spark plug wires and the problem was gone. The car runs fine now.
Thanks for the help everyone.
valos
Honda Civic (2001 - 2005)
08-09-2016 07:47 AM
