Engine dies after reaching Rev limit!
Old 03-10-2012, 05:47 AM
Jabbito's Avatar
Default Engine dies after reaching Rev limit!
Hello H-T
need help on something, My Engine shuts off while running after reaching my rev limit ( 7.5k rpm) but seems to be ok after i turned it on.
No cell on ecu, and my ecu was just recently tuned
thanks
Old 03-10-2012, 07:47 AM
blkSi's Avatar
Default Re: Engine dies after reaching Rev limit!
I know I can't help you...
But you MIGHT need to provide more information about your setup before anybody can.
Hope you find the problem!
Old 03-10-2012, 09:02 AM
Jabbito's Avatar
oh sorry about that...
im running on a d16y7 or y8 vtec-e, all stock engine, recently chrome tuned, rev limit was set to 7.5k rpm
Old 03-11-2012, 05:39 PM
vtec8200's Avatar
does it do that since the tune?
Old 03-12-2012, 03:22 AM
Moderator
crazes's Avatar
look at your distrubutor. it might be going bad. happened to me at the track
Old 03-12-2012, 04:36 PM
type_r_teggy's Avatar
my setup did that on crome 2, but i TINK its ignition cut vs fuel cut.
Old 03-13-2012, 03:39 PM
SiR-iNTEGRa's Avatar
Not sure if I'm understanding u rite but u said u have the rev limiter at 75rpm and it cuts off after u pass it.......could be that the person who tuned ur ecu left the rev limiter on ur car cuts off as a safety measure so u don't blow ur motor its probably ur ignition cut off just change ur cut off limiter to a higher point
Old 11-08-2015, 03:24 PM
Langford360's Avatar
ever find the cause to the issue?
specialized108
12-31-2008 10:44 AM
EG-tofu
Honda S2000
91
12-02-2007 05:45 PM
Tchleung
05-31-2006 10:30 PM
jdmsiblue1
05-25-2006 06:43 PM
eknine
07-18-2003 08:06 PM
Quick Reply: Engine dies after reaching Rev limit!
