Blox Velocity Stack and Filter ~DYNO COMPARISON~
Old 09-15-2009, 12:30 PM
B16CRXT's Avatar
Default Blox Velocity Stack and Filter ~DYNO COMPARISON~
Hey guys. On Sept. 12th I went to a dyno day so I could test a new intake setup I got. I got the Blox velocity stack and Blox filter. I wanted to see what, if any increase there would be in power versus my current setup. Currently it’s just a 3” intake with a basic filter on it. Keep in mind that this is all unturned. I’m running a stock obd1 gsr ecu in my CRX.
The rest of the setup is as follows:
Stock obd2 GSR motor
RMF replica header
2.25” exhaust with no cat, exiting a stock replacement muffler to keep it quiet for daily driving.
Stock tb and intake manifold. I’ve never been able to confirm if the secondary butterflies work properly. Every test I tried, showed me nothing and I cannot hear them open up.
1st run-Green-Original intake setup
2nd run-Red-only velocity stack
3rd run-Blue-velocity stack with filter
Overall, it did much better without the filter on the velocity stack. It yielded better hp and torque through the power band until about 6000 RPM, where all the set ups kind of equalize and it comes back out on top at peak rpm.
The stack with the filter on it yielded more hp and tq between 6K and 7K RPM. Until you get to 5500 RPM, the stack and filter perform about the same as the old set up.
Old 09-15-2009, 12:56 PM
Not to be confused with "THE MAN"
THE GUY's Avatar
Default Re: Blox Velocity Stack and Filter ~DYNO COMPARISON~
Damn Chris you got some hairy arms!!
Old 09-15-2009, 01:03 PM
B16CRXT's Avatar
lol, I've never claimed not to be a hairy guy. lol
Old 09-15-2009, 09:27 PM
numberone's Avatar
That stock IM is killing you bro!
Old 09-15-2009, 09:32 PM
Clutch_199's Avatar
i was wondering about those, and what one i was going to use, not half bad, think i might run that on my eg6
Old 09-15-2009, 09:42 PM
B16CRXT's Avatar
yea, and the restrictive-ish exhaust. the exhaust keeps me out of trouble though, so I don't complain much. I have been wanting to get the s2p manifold, but money has been kinda tight.
Old 09-15-2009, 11:01 PM
Slain's Avatar
looks like the secondaries open to me according to your dyno plots
Old 09-16-2009, 04:57 AM
lohatch's Avatar
is that a copy of the BPI velocity stack? it looks simular from the underside
Old 09-16-2009, 05:16 AM
Furyof4's Avatar
You bet, exact copy.
Old 09-16-2009, 06:50 AM
OH_1fstgsr's Avatar
The secondaries are NOT opening, unless you wired in a relay to have them open. The OBD1 and OBD2 ECU operated the secondaries differently. Between 4600-5800 you're running rich. Normally the secondaries have change the air flow so the ECU is putting more fuel in.
Get this sucker tuned and clean up the A/F.
What kind of gains did you get from 6k up? Looks like about 5hp or so.
Old 09-16-2009, 06:52 AM
B16CRXT's Avatar
I was thinking the same thing. I never felt that pick up at 6K until I installed the RMF header though, so I just thought it was the header doing some good for my top end.
Yep! The velocity stacks are identical, but the filters may be different. BPI's filter costs about 2X as much.
Old 09-16-2009, 07:09 AM
B16CRXT's Avatar
So for the butterflies to work with an obd1 ecu there is a relay in line? Everyone told me it just wired to the ecu back when I was doing the wiring. Do you have any idea how to wire the relay? I'll probably get a tune once I get the IM.
Old 09-16-2009, 07:16 AM
OH_1fstgsr's Avatar
I have an OBD2 engine and a OBD1 ECU running my 1999 GSR right now. I am running a Hondata S300.
You need a relay. This is a fact, period. Why, OBD1 ECU is a negative ground and the OBD2 ECU is a positive ground for the IAB circuit. I might have this backwards but regardless you will need a relay.
If you have your car tuned correctly it should almost sound like to have two VTEC points. Actual VTEC and when the IAB open up. This actually sounds really cool.
I don't know how to wire the relay, my tuner did it. I could try to take a picture.
Old 09-16-2009, 07:39 AM
DDTECH's Avatar
Good comparision.
On my itr, i put a 3'' SRI and vstack w/o filter.
Had to add over 15% fuel all over the map just to get the AFR back to normal.. picked up some good power.. specially up top..
Love bpi vstacks.
Old 09-16-2009, 07:57 AM
THE GUY's Avatar
Chris if you can wait till I get my car back up to SC I'll sell you the AEBS manifold and port matched TB out of the GSR for less than the S2P will run you. Or get in touch with Alex from Humble Performance on here he is a sponsor. He took great care of me when I got my AEBS from him.
Oh and your a gay fish.
Old 09-16-2009, 10:03 AM
B16CRXT's Avatar
a picture or a simple diagram made in MS paint would do just fine. Did you get the relay from honda? I'm going to text JD and see if he knows how to wire it up....nobody told me about this when I was wiring everything up for this motor...lame.
Old 09-16-2009, 10:36 AM
OH_1fstgsr's Avatar
I can talk to my tuner. I actually found out about this on HONDATA's site. I was asking some questions about in there forum. I'll see if I can find the details, it was a number of years ago.
You may want to ask this question in the Engine Management and Tuning forum. Someone might have details more easily available.
Old 09-16-2009, 12:19 PM
WrongWD's Avatar
Interesting, I also tested this out of curiosity. My results had a slightly more drastic difference:
Red: Shop "magic arm" intake
Blue: 3" Short Ram with Blox Velocity Stack
Yellow: 3" Short Ram with Blox Velocity Stack and Blox Filter
Don't mean to threadjack, just want to contribute
Old 09-16-2009, 12:29 PM
B16CRXT's Avatar
You sure you got the Legend correct on your post? If so, you are saying that you made better power without the blox stuff.
Old 09-16-2009, 01:01 PM
WrongWD's Avatar
correct, i did make the most power without it. the shop intake is like a 4 foot long intake with a no-name big velocity stack on the end.
Old 09-16-2009, 02:16 PM
B16CRXT's Avatar
Interesting! Was it actually an intake or just some 4 foot long piece of pipe? At that length, I dont see how it could fit under the hood! LOL
Old 09-16-2009, 02:47 PM
Mike95lude's Avatar
WrongWD - What kind of setup is the "Shop "magic arm" intake"? Please tell us more.
Old 09-16-2009, 06:28 PM
WrongWD's Avatar
It's a pretty common setup, lots of dyno operators have one lying around. It isn't really designed to fit in the engine bay, it just sort of sticks out with the hood up. Although, some drag racers remove the passenger side headlight, and have one stick out there with a velocity stack on the end.
basically, it looks like a short ram, but instead of the long section being like 12", its like three feet or so.
here is an example:
(not mine)
here is my short ram for comparison:
Old 09-16-2009, 08:30 PM
1.5Slowmatic's Avatar
anyone do a cold air with a vstack?
Old 09-16-2009, 09:00 PM
KevinT707's Avatar
So in conclusion, besides WrongWD's "Magic Arm" with velocity stack no one else has made any significant gains in power with a velocity stack with/without filter.
Quick Reply: Blox Velocity Stack and Filter ~DYNO COMPARISON~
