B18B3 redline at 8000, B18B1??
Old 11-21-2009, 03:22 PM
Hatorade's Avatar
Default B18B3 redline at 8000, B18B1??
So I was looking at the specs of the B18B3 VS the B18B1.
The B18B3 has a redline of 8,000 rpm stock.
  • Displacement: 1834cc
  • Stroke: 89 mm (3.5 in)
  • Rod Length: 137.01 mm (5.394 in)
  • Rod/Stroke Ratio: 1.54
  • Power:
  • Redline: 8000 rpm
Where as the B18B1 has a redline of 7,200 rpm stock.
  • Displacement: 1,834 cc (111.9 cu in)
  • Compression: 9.2:1
  • Bore: 81 mm (3.2 in)
  • Rod Length:5.394in
  • Power: 142 hp (106 kW) @ 6300 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
  • Redline: 6800 rpm
Looking at stroke, rod length and R/S ratio, everything is the same. Does this mean that the B18B1 can rev to 8,000rpm redline as well?
I am asking b/c I am thinking of going Budget LsV and avoiding bottom end work would save a lot of money.
thanks
Old 11-21-2009, 03:58 PM
88Hatchy's Avatar
Default Re: B18B3 redline at 8000, B18B1??
wtf is a B18B3?
Old 11-21-2009, 05:26 PM
sohcnotec's Avatar
wiki says it came in the Honda Ballade 180i/E
seems to be the African version of a Civic???
Old 11-21-2009, 06:13 PM
komat's Avatar
i reved my complete stock b18b to 8200rpm everyday. it was also turbo with a t3/t4 57trim 10psi. i sat on the rev limiter to get traction. i did it for a year didnt have any problems.
just change the rod bolts to arp and you be golden if you are worried
Old 11-21-2009, 09:27 PM
Scott_Tucker's Avatar
Mean piston speed at 8000 rpm on an engine with a 3.5" stroke would be 4648 feet per minute which is below the generally accepted maximum of 5000 fpm. Just use good rod bolts and you should be OK.
Old 11-21-2009, 09:52 PM
All Motor Mentor
00Red_SiR's Avatar
The stock cams used may have been the deciding factor for the different redlines.
Old 11-22-2009, 08:10 AM
I would agree with this. What are the differences in stock static compression ratios? Are the port sizes different in the heads?
Old 11-23-2009, 03:32 AM
Meister vtec's Avatar
read this thread https://honda-tech.com/forums/showth...4#post39038834
it is obvious wiki has the specs wrong and is not trustworthy as usual!
Old 11-23-2009, 01:13 PM
Hatorade's Avatar
^^^ ahhh...thanks...that makes sense
For a moment, I thought that IF the bottom end could rev safely to under 8,000 from the factory, it would make LsV a lot easier for a lot of people.
Unfortunately, buying a vtec longblock will still be a cheaper way of going vtec.
thanks!
/thread
White V6
07-16-2005 04:06 PM
ChrisShen
11
10-04-2004 03:33 PM
ChrisShen
10-03-2004 04:25 AM
Screamer
119
05-06-2004 07:20 AM
90teg
08-01-2002 10:41 AM
Quick Reply: B18B3 redline at 8000, B18B1??
