Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
TSX specs compaired to RSX
Old 10-16-2003, 10:00 AM
LucasMS's Avatar
Default TSX specs compaired to RSX
I know they are both K-blocks, but how are the bore, stroke, heads, valves and all that stuff compair. Can I run RSX parts on a TSX or is it like the B20/B16-18 bore differences??? Specs like that are hard to come by.
Old 10-16-2003, 10:18 AM
1abSi's Avatar
Default Re: TSX specs compaired to RSX (LucasMS)
ummm not really hard to come by...it is called "SEARCH"
here are the TSX specs
http://www.vtec.net/articles/v...75679
Modified by 1abSi at 2:31 PM 10/16/2003
Boilermaker1's Avatar
I belive the K24 Bore is 1mm larger, and the stroke is 101mm vs. 86mm.
Old 10-16-2003, 10:31 AM
1abSi's Avatar
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">I belive the K24 Bore is 1mm larger, and the stroke is 101mm vs. 86mm.</TD></TR></TABLE>close...it is 87 for the bore..but stroke is 99mm
Old 10-16-2003, 03:21 PM
LucasMS's Avatar
Default Re: (1abSi)
Thanks, are the heads the same? Thats more of a concern for me at this point. Are the blocks different heights? Trying to research the exchange of RSX performance parts to a TSX engine.
Old 10-17-2003, 03:35 AM
arctic-k20's Avatar
the k24 block is higher
the heads are similar but the k20a2 revs higher = flows better
Old 10-22-2003, 10:44 PM
HapaHaole's Avatar
Default Re: (arctic-k20)
higher revs does not = better flowing heads. some people say the TSX head is the same as the RSX type S head. some people even think you can take type S rocker arms and cams and install them into a k20a3 and have complete ivtec. some people say that the a3 head has smaller ports than a type S (k20a2 and jdm k20a) heads.
bottom line is that the 99mm stroke is made for some low end torque and not high revving top end hp. thats the way honda designed it. a 99mm stroke crank isnt all that practical in factory production car as a high revving motor, its just so heavy and works best spinning a little slower.
Old 10-29-2003, 02:37 AM
al4t1gbundy's Avatar
well said SBE
HalfManHalfFred
05-15-2006 03:53 PM
mvaccoRd
13
12-29-2003 12:58 PM
04accordcoupe
38
09-24-2003 04:21 PM
Lonerider
05-28-2002 09:40 AM
Perfectionist
19
03-30-2002 01:54 PM
Quick Reply: TSX specs compaired to RSX
