Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
press gas, car shakes
Old 04-05-2008, 04:53 PM
202B's Avatar
Default press gas, car shakes
hello,
I was wondering if anyone had this problem.
When i press the gas, the car begins to shake...Is it possible that its the alignment or wheel balancing?
Maybe bent rim?
Does anyone else have this problem?
thanks
Old 04-06-2008, 08:21 AM
2005 TSX's Avatar
Default 202B
So,
a.) you press the gas pedal, car moves at speed, and then begins to shake?
Or...
b.) You press the gas pedal and the engine makes the whole car shake?
I going out on a limb by saying either,
a.) Tires out of balance
or,
b.) Engine mounts are destroyed
Do you have any more information for us?
Modified by 2005 TSX at 3:59 PM 4/6/2008
Old 04-06-2008, 10:22 AM
202B's Avatar
Default Re: 202B (2005 TSX)
I press the gas padel and the car moves and shakes.....
I just got a tire balance and I still have the same problem....
Oh man....
Engine mounts can cause this....they checked the alignment and it is only slightly off
I don't think that can cause it
Old 04-06-2008, 08:36 PM
.::miLan's Avatar
Default Re: 202B (202B)
Is there anything else associated with the shaking - i.e., abnormal noises? Does the steering wheel shake excessively or the entire car?
Old 04-07-2008, 11:40 AM
202B's Avatar
Well I am dropping off the car to the stealership....
Hopefully they can fix it before saturday...
I will keep you all updated....
a mechanic on sunday said it could be:
motor mount
cv joint
axle
Old 04-12-2008, 12:51 PM
evertp1's Avatar
Default Re: (202B)
ghey
Old 04-14-2008, 07:48 AM
202B's Avatar
now the car is being sent to acura....
ughhh....
they did everything they could and it still is not driveable the mechanic said...i am furious
Old 04-14-2008, 09:41 AM
jgirard's Avatar
Default Re: (202B)
does it shake when you don't give it gas and you are rolling? If it doesn't then it's probably an axle
Old 04-14-2008, 11:38 AM
202B's Avatar
jgirard, It shakes when I press the gas. As soon as I get to the desired speed and let go, Shaking is gone.
They did whatever basic problem finding they did. Then they did take the axles out. They did not find anything wrong.
They are dumbfounded
Petah
Honda Civic (2001 - 2005)
11-22-2010 06:40 PM
quickster
11-11-2010 06:29 AM
nhip101
Honda Civic (2006 - 2015)
02-11-2008 09:41 AM
bluehatchy
28
09-02-2004 12:56 AM
Quick Reply: press gas, car shakes
