Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
K24A1 vs K24A2 vs K24A4 Short Blocks
Old 10-21-2005, 07:04 AM
Dougie Pants's Avatar
Default K24A1 vs K24A2 vs K24A4 Short Blocks
So I'm not getting many answers from the boys and girls on K20A.org on this. I know that the K24A1 has lower compression than the K24A2 and does not have the Oil Squirters as well. Are there any other differences like main caps or girdle?
Old 10-22-2005, 04:35 PM
ZygSpeed's Avatar
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Dougie Pants)
What year cars have those motors?
Old 10-27-2005, 08:28 AM
Nikos's Avatar
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougie Pants &raquo;</TD></TR><TR><TD CLASS="quote">So I'm not getting many answers from the boys and girls on K20A.org on this. I know that the K24A1 has lower compression than the K24A2 and does not have the Oil Squirters as well. Are there any other differences like main caps or girdle?</TD></TR></TABLE>
Well,
these are the accord, element, crv and tsx blocks.
Are you asking about bare blocks or what?
Each girldle comes with the block so you cannot buy one on its own. In case you want to mix and match, you could have it decked etc...
All these blocks for the most parts use the same parts. yes, the TSX has oil squirters but when sleeving a block we have been adding the oil jets to non tsx k24a blocks.
Only major difference in bare blocks is that the CRV block can take a type s oil pump with less trouble then a tsx, accord, element block.
here's how a type s oil pump is fitted on an accord block
Old 10-29-2005, 01:10 PM
* B A N N E D *
Oregon's Avatar
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Nikos)
Contact chad_everson on Honda-tech He's knows ALOT about K-series
Old 10-30-2007, 07:57 AM
onefstek's Avatar
Default Re: K24A1 vs K24A2 vs K24A4 Short Blocks (Oregon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon &raquo;</TD></TR><TR><TD CLASS="quote">Contact chad_everson on Honda-tech He's knows ALOT about K-series </TD></TR></TABLE>
Chad don't know crap. You can tell him I said so. lol
Old 10-31-2007, 12:02 PM
evertp1's Avatar
I HOPE THIS HELPS
K24A1
* Found in:
o 2002-2006 Honda CR-V
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 9.6:1
+ Power: 156 hp (119 kW) @ 6000 rpm
+ Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
+ Redline: 6500 rpm
K24A2
* Found in:
o 2004-2008 Acura TSX
+ Compression: 10.5:1
+ Power: 200 hp (147 kW) @ 6800 rpm (2004-2005)
+ Power: 205 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04
+ Torque: 166 ft·lbf (225 N·m) @ 4500 rpm (2004-2005)
+ Torque: 164 ft·lbf (222 N·m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04
+ Redline: 7100 rpm
K24A3
* Found in:
o 2003-2006 Honda Accord (Europe, Japan, and Australia)
+ Power: 189 hp (140 kW) @ 6800 rpm
+ Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
+ Redline: 7000 rpm
K24A4
* Found in:
o 2003-2005 Honda Accord, 2003-2008 Honda Element
+ Compression: 9.7:1
+ Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
+ Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpm in 2007/2008)
+ Redline: 6500 rpm
K24A8
* Found in:
o 2006-2008 Honda Accord
+ Power: 166 hp (124 kW) @ 6000 rpm (2006/2007)
+ Power: 177 hp (132 kW) @ 6500 rpm (2008 LX) and 190 hp (140 kW) @ 7000 rpm (2008 EX)
+ Torque: 160 ft·lbf (217 N·m) @ 4250 rpm (2006/2007)
+ Torque: 161 ft·lbf (218 N·m) @ 4300 rpm (2008 LX) and 162 ft·lbf (220 N·m) @ 4400 rpm (2008 EX)
+ Redline: 6500 rpm
+ Redline: 6800 rpm (LX) /7100 rpm (EX)
K24Z1
* Found in:
o 2007-2008 Honda CR-V
+ Power: 156 hp (119 kW) @ 6000 rpm (166 hp @ 5800 rpm in 2007/2008)
+ Torque: 161 ft·lbf (220 N·m) @ 4200 rpm
+ Redline: 6500 rpm
Old 11-01-2007, 05:06 AM
evertp1's Avatar
DO NOT put a K20A or A2 head on any K24 block and expect it to do 8000rpm
Old 11-04-2007, 10:04 AM
JDMsam.'s Avatar
Default Re: (evertp1)
that k20 heads + k24 block= nonreliable
Old 11-04-2007, 10:14 AM
onefstek's Avatar
Default Re: (JDMsam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMsam. &raquo;</TD></TR><TR><TD CLASS="quote">that k20 heads + k24 block= nonreliable </TD></TR></TABLE>
why do you say that?
Old 12-04-2007, 06:17 AM
evertp1's Avatar
Basically the K24 is the New B20 and the K20 is the B18C5... my 2004 TSX has 205 BHP, and a 2002 RSX Type S put outs the samthing with less torque... it wouldnt make sense to put a K20 head on a K24 block...
K20 was made for High HP and high RPM... the K24 is for Torque... so if you want one or the other, buy a RSX or a TSX
Old 12-08-2007, 07:21 PM
donz's Avatar
wow, r u kidding? Please look into the flow of the k20 head. Sure there is no 8000 rpm, but the extra torque makes up for that and more.
Please check k20.org before making yourself look bad.
have you heard of honda challenge?
Old 12-08-2007, 07:38 PM
evertp1's Avatar
Default Re: (donz)
how am i making myself look bad? i know the K20a head is made for flow... its made so the air can flow freely at those high RPMs, thats why the K20 has a K20 head and a K24 head is different head! where could I have possibly gone wrong?
Old 03-10-2010, 06:45 PM
VtecNotRequired's Avatar
Default Re: (donz)
really sorry to bring this back from 07 but i was googling K24 differences and this was the first option. this is the funniest **** ive read in a while and thought you guys would like a good laugh too.
Old 03-10-2010, 08:22 PM
JDM FERIO RS's Avatar
Actually if you put a k20 head on a k24 block its all about tuning. Yes u may not have the high rpms like a k20a,k20a2,k20z1,k20z3 but its all bout tq in the heavier cars. I personally have a k20/24 frank swap in my fg2 and let me tell you im very pleased with my low end and top end tq. Yea u Can rev the k20a,k20a2,k20z1,k20z3 motors to 8200-8500 depending if you have flash pro, kpro but with no tq its point less. And the tsx head is very similar to all the others except it has a dif intake manifolf but it still uses the real vtec mechanism unlike the accord and crv and element. With my I/H/E, TBS,FP using hondata calibration my beast has about whats listed on its website but shy of the tq by a few ticks. But 275 whp and 205 tq is good enough for a few bolt ons and flashpro. So my advice to to anyone the extra tq is def a dif maker in any car but in a few yrs when every body is swappin 2.0 blocks for 2.4 just remember what I said its 2.4 FTW
Old 03-11-2010, 10:46 AM
Mr. DB2's Avatar
I went from an 08 Si sedan(K20Z3) to an 04 6-speed TSX(K24A2) and the two are very different. Yes the Si is a tad bit quicker light to light,but was slower from an 60mph plus roll. The torque and constant feel of the K24A2 is much better for city driving and/or having passengers. The Si in city driving or with 1 or 2 people felt very sluggish if you didn't rev the **** out of it. Of course the Si had the "cool" loud as hell vtec crossover(didn't have nothing on my old 92 GS-R),but I kinda enjoy not broadcasting to the world that I'm accelerating(especially bored cops). It all depends what you want out of your engine and what kind of driving you do with it.
Old 03-11-2010, 12:11 PM
lol i wasnt really trying to start this thread back up, i know this already and thats why reading it was just funny, the guy a few posts up dont even know what hes talking about
Old 03-12-2010, 10:04 AM
20-EM2-05's Avatar
Naw really!? It was back in 07 where K swaps were still rare to see compared to seeing one every day.
I bet if we went back to 1998, no one ever heard of b20v or a b20 swap.
Old 03-12-2010, 11:37 AM
Mr. DB2's Avatar
^Acually in 1998 b20's where in alot of hatches in my native homeland of Miami. B20's using LS or GSR trani's,LS intake manifolds,and chipped ecu's.Very cheap alternative. They were even cheaper that LS engines at the time..
Old 03-12-2010, 12:12 PM
20-EM2-05's Avatar
But they weren't as popular as they are now, since people have discovered their potential by having it vtec.
Old 03-15-2010, 02:12 PM
Mr. DB2's Avatar
I think their popularity has died down with K-series & J-sreies swaps taking over.
Old 11-11-2011, 09:34 PM
black and pink's Avatar
so which is better stock k24a2 with bolt ons an kpro? or frank k20a2/ k24a1 with bolt ons and kpro?
Old 01-09-2012, 08:09 PM
neihouse123's Avatar
i kinda would like the answer to the aformentioned question by Black and Pink
Old 01-24-2012, 07:47 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I would say the Frankenstein would be better. IT is the reason I got back into the Honda scene. I had one blow the doors off me with simple bolt ons and a tune
Old 02-08-2012, 06:57 AM
949's Avatar
I HOPE THIS HELPS
K24A1
* Found in:
+ Redline: 6500 rpm
K24A2
* Found in:
+ Redline: 7100 rpm
K24A3
* Found in:
+ Redline: 7000 rpm
K24A4
* Found in:
+ Redline: 6500 rpm
K24A8
* Found in:
+ Redline: 6500 rpm
K24Z1
* Found in:
+ Redline: 6500 rpm
so what is popular now a days?
and why?
Mugencrxsir1
03-28-2011 05:54 AM
boostd ls
10
04-22-2008 11:24 AM
Da1spaz247
02-14-2006 06:44 AM
CHEETAH
03-11-2005 06:03 AM
kenbdSi
05-26-2004 09:25 AM
Quick Reply: K24A1 vs K24A2 vs K24A4 Short Blocks
