Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
putting rsx type s gears into tsx. both 6speed.
Old 07-27-2012, 03:23 PM
track_assassin's Avatar
Default putting rsx type s gears into tsx. both 6speed.
both trans have 6 speeds. i search and could not find what i was looking for.
i know you can put tsx gears into the rsx. but what would i need to put rsx gears into the tsx. what bearings would i need, ? if any? what other things may i need?
thanks for the help
Old 07-27-2012, 09:07 PM
boostedteggy718's Avatar
Default Re: putting rsx type s gears into tsx. both 6speed.
i broke my tsx second gear . all i did was swap the whole rsx internals into my tsx casing and i had a spacer behind the speed sensor . if you dont put the spacer in correctly you gonna break it and i broke 4 of them before getting it right
Old 07-29-2012, 04:42 PM
96 GSR-T's Avatar
Pretty sure you use w/e bearing match the case, and I do know for sure you want to reuse the TSX shift forks... otherswise its a direct swap. Make sure you check clearances as listed in the service manual.
Old 07-30-2012, 06:39 AM
manekDC2.'s Avatar
what if you interchanged some of them between the tsx and rsx-s to get a better gear ratio... i heard of some people doing this on k20, but never got the exact ultimate setup.
Old 08-02-2012, 04:55 PM
96 GSR-T's Avatar
So whats your question? lol I am not sure if the shafts are the same for the gears to fit if you pick and choose between the 2. I know more about B series stuff my turbo car had a B16 1-3 and GSR 4-5 in a GSR case, but I had to use the B16 shafts to make it work.
The ideal ratio's will be easy to determine with one of the many online honda gear calculators.
Old 03-13-2017, 06:25 AM
Angel420's Avatar
can u explain exactly hownu did this im having same problem now with speed sensor thanks
Sccacivic1997
01-17-2014 10:26 AM
Jahaziel
01-13-2011 05:48 PM
ryanjvoss
09-27-2010 08:39 AM
sol_searchin
01-10-2010 06:43 AM
jdmintegra1994
12
11-20-2003 05:11 AM
Quick Reply: putting rsx type s gears into tsx. both 6speed.
