Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
P0740 code on 2001 TL
Old 02-26-2008, 07:25 PM
db1_jdm's Avatar
Default P0740 code on 2001 TL
I know the code stands for the TCC malfunction, but what exactly does this mean? And can someone help me point out the torque converter clutch? Thanks in advance
http://acuraautomotiveparts.or...ormal
Old 02-26-2008, 08:17 PM
conme's Avatar
Default Re: P0740 code on 2001 TL (db1_jdm)
DTC P0740: Problem in Lock-up Control System
You, probably need a Transmission.
Old 02-26-2008, 10:18 PM
db1_jdm's Avatar
Default Re: P0740 code on 2001 TL (conme)
Im sure its rebuildable though,
Old 02-28-2008, 05:32 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db1_jdm &raquo;</TD></TR><TR><TD CLASS="quote">Im sure its rebuildable though, </TD></TR></TABLE>Good luck with the rebuild.....I know people that have gone that route and still end up going to the dealership with tranny problems.
Old 03-02-2008, 09:09 AM
high_revs's Avatar
when we get accords with that code at my dealer we just order a tranny....dont even bother waisting more time, your trans is shot...i wouldnt recommend you trying to rebuild it either.
Old 03-09-2008, 12:11 AM
mr cx hatch's Avatar
Default Re: (high_revs)
check with your dealer. maybe they have a warranty extention for your vehicle.. you might not have to pay a penny and they'll give you a new tranny.. or if they do decide to charge you, just ask for a one time goodwill gesture.. they'll usually say ok if you bitch enough
Old 03-19-2008, 08:05 PM
YeuEmMaiMai's Avatar
milage on the car?
warranty is 7 years 9 months from "in service date" or 109K miles (114K if you take into account the other settlement involving the odometer being off where honda added 5% to lease milage and warranty work milage limits)
Old 03-27-2008, 05:07 AM
dixie Normas7's Avatar
you need a trans buddy.. p0740 is tourqe converter lock up. a common code found in thos when the trans takes a dump. p0740, p0730, or p0780 any of those three codes means u pretty much have to replace your trans
Old 03-29-2008, 07:04 PM
hilltopgraphics's Avatar
Default Re: P0740 code on 2001 TL (dixie Normas7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dixie Normas7 &raquo;</TD></TR><TR><TD CLASS="quote">you need a trans buddy.. p0740 is tourqe converter lock up. a common code found in thos when the trans takes a dump. p0740, p0730, or p0780 any of those three codes means u pretty much have to replace your trans</TD></TR></TABLE>
Not necessarily true. Most people are unaware that a P0740 DTC is much more vulnerable than a 730 or 780. Since the TCC is directly related to fuel economy, the feds have mandated this. The quickest check is going to be removing the TCC solenoid and checking the filter screen for clutch material. If there's clutch material, you've certainly got problems. If the filter screen is clean, the next step is to drop the tranny and remove your torque converter to check the o-ring for nicks, slivers or damage. A simple flat spot on the o-ring can cause a P0740 DTC. If nothing is wrong with the o-ring, wait it out. Have the dealer clear the code. If you're not noticing a driveability issue, chances are a small piece of contamination has passed through either the L/C control valve, L/C shift valve or L/C timing valve. If that's the case, you should be fine.
VERGOTEx3
Honda Civic (2001 - 2005)
08-22-2010 09:02 PM
VAAJ
36
05-07-2009 07:35 PM
knightnam
01-05-2008 09:05 PM
NathanielH
05-25-2006 11:29 PM
AMG
09-02-2003 07:03 AM
Quick Reply: P0740 code on 2001 TL
