RSX type s PO341
Old 11-29-2011, 11:33 AM
thaoboy89's Avatar
Default RSX type s PO341
need help...that is shown on a obd2 reader..any suggestion?
po118?p01362?po341?anyone hae any idea?2002 rsx type s
Old 11-29-2011, 02:45 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: RSX type s PO341
P0118 Engine Coolant Temperature Circuit High Input
P1362 which is the TDC code, or camshaft position sensor
What have you tried if anything? I would look at your cam sensors. I have seen some gone bad before. . .
Old 11-29-2011, 02:53 PM
thaoboy89's Avatar
i switch the cam senor..but where is the 1362 n 118 located at?any picture where i can find them?
Old 11-29-2011, 03:50 PM
thaoboy89's Avatar
po1632 n po341 is gone but its just showing
P0118 Engine Coolant Temperature Circuit High Input where can i find that at?
thaoboy89's Avatar
Old 11-29-2011, 05:36 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Well the coolant temperature sensor is the white plastic one in the picture
Old 11-29-2011, 05:49 PM
thaoboy89's Avatar
thanks got that..but the Po341 is back on again..i switch it to a new one it came back on
Old 11-29-2011, 05:57 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Well there are two cam sensors... which did you change?
Old 11-29-2011, 06:13 PM
thaoboy89's Avatar
both of them..still came back on n i switch both of them around 2
Old 11-29-2011, 06:17 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
well technically speaking the Crank Position sensor works hand in hand with the cam sensors for the engine to accurately read timing. So it could be a crank sensor... sucks having a guessing game unless you have a REALLY expensive scanner that tells you exactly what it is.
DR_WANKEL
10-12-2009 07:10 PM
-Championship-
07-19-2006 08:04 AM
Quick Reply: RSX type s PO341
