Please HELP (YES I SEARCHED) swapping a k24a4 into a ep3
Old 07-23-2007, 08:53 PM
eghatch4sale's Avatar
Default Please HELP (YES I SEARCHED) swapping a k24a4 into a ep3
im new to the whole ep3 world not really sure what will need to be done to put a k24a4 into a ep3 i searched and couldnt really find any info on swaps besides the k20a ............ any help or links will be greatly appreciated
Old 07-24-2007, 04:47 AM
wow not one person offering help ........ its not like im a noob i have been a member on this board for a long time
Old 07-24-2007, 07:49 AM
B33R's Avatar
Default Re: (eghatch4sale)
Try Ephatch.com
Old 07-24-2007, 10:29 AM
already tried that all i can find is info on swapping a k24 with a k20 head
Old 07-24-2007, 11:36 AM
dc5RickK20's Avatar
Default Re: Please HELP (YES I SEARCHED) swapping a k24a4 into a ep3 (eghatch4sale)
are you gonna swap just the k24 or are you going to do a hybrid k20/k24
Old 07-24-2007, 11:42 AM
GDD4LIFE
phthalo's Avatar
Default Re: Please HELP (dc5RickK20)
did you try k20a.org?
Old 07-24-2007, 11:50 AM
i just plan on swapping just the k24a4 into the car i have searched high and low i spent a couple hours last night going threw thread but couldnt find out enough info
Old 07-24-2007, 12:04 PM
bryce-o's Avatar
https://honda-tech.com/zerothread?id=1918510
try searching archived content, there were more results than just this one
Old 07-24-2007, 12:12 PM
doesnt have the info i need ...................
i need to know what i will need from the k24a4 and what will i need from the k20a3 i need to know what mounts im going to need ....... i need to know if i can use the k20a3 harness ....... any rewiring needed if the throttle cable is going to work or if im going to need one fron a different car ......... etc .................
Old 07-24-2007, 12:53 PM
bryce-o's Avatar
http://forums.clubrsx.com/show...4+EP3
how about this?
Old 07-24-2007, 01:59 PM
MidNit's Avatar
Default Re: (bryce-o)
You will need the CRV passenger side motor mount. You can use the rest of the stock ep3 motor mounts. The engine will sit about 19mm higher, you will have to use the k20a3 intake manifold and header unless you already have aftermarket.
Also, if you have KPro you can use your stock ep3 wiring harness then.
This is all from my k24a2 swap, they're the same block with a different head, so it should all be the same.
Any other specific questions? I will try to help or I probably know someone who knows the answer if I don't know it myself.
ish-ef
12-19-2008 07:45 AM
illmob
01-27-2008 09:32 AM
johnE ej
07-21-2006 08:33 AM
dip-set
03-04-2004 07:38 AM
STEALTHMODECOUPE
07-22-2003 06:43 PM
Quick Reply: Please HELP (YES I SEARCHED) swapping a k24a4 into a ep3
