Where is the Fast Idle Thermo Valve?
Old 05-13-2002, 08:50 PM
comptechgsr2000
Guest
Posts: n/a
Default Where is the Fast Idle Thermo Valve?
Where is the Fast Idle Thermo Valve? Is it behind the intake manifold?
Old 05-13-2002, 09:00 PM
Global Moderator
Reid's Avatar
Default Re: Where is the Fast Idle Thermo Valve? (comptechgsr2000)
On a GSR intake manifold, it's located near the firewall on the manifold. It's visible from above.
But I must ask, out of curiousity, why did you ask in this forum?
Old 05-13-2002, 09:05 PM
Rory Breaker's Avatar
Correction, on a GSR its directly ON the underside of the throttle body, held on by 3 10mm's.
Old 05-13-2002, 09:06 PM
Global Moderator
Reid's Avatar
Default Re: Where is the Fast Idle Thermo Valve? (newgsrdriver)
Actually that's the exact place I'm describing. Was I not clear?
Old 05-13-2002, 09:15 PM
Default Re: Where is the Fast Idle Thermo Valve? (Reid)
Near the firewall on the manifold is an accurate description of a part located under the throttle body, not touching the manifold in any way other than a coolant hose? News to me!
illprelude
07-11-2008 05:04 AM
hectic57
03-19-2008 08:16 AM
bobukler
05-29-2006 08:50 PM
turboed4life
05-15-2004 12:14 PM
b16hybrid2
06-10-2003 05:46 AM
Quick Reply: Where is the Fast Idle Thermo Valve?
