Tires rotated, now car pulls left?
Old 10-20-2004, 12:50 PM
onyx00's Avatar
Default Tires rotated, now car pulls left?
I had a local shop rotate my tires while thye were changing my oil. Now the car pulls left.
Is it possible the lift they used somehow messed up the alignment, or is it more likely one of the tires up front is pushing or pulling?
I checked tire pressure, and all is well there (36 fronts, 34 rears).
Wondering if I need to spend another $80 on alignment (had it done this summer already).
Old 10-20-2004, 01:03 PM
WowOzYouRock's Avatar
Default Re: Tires rotated, now car pulls left? (onyx00)
is it still in the same rotation?... well, just wait til it wear out a bit and even the wear on the tires ... then get it align if it continue pulling....
Old 10-20-2004, 01:11 PM
mstewar's Avatar
most alignment shops warranty the alignment for x amount of miles.. call the shop that did it and ask..
no lift I've seen should have done anything to do with your alignment..
Old 10-20-2004, 01:19 PM
Track rat's Avatar
Default Re: Tires rotated, now car pulls left? (mstewar)
If your bring an unevenly worn tire from the back to the front it can make it pull left or right. Swap your fronts from left to right and see if the pull goes away or pulls the other way.
Old 10-20-2004, 01:23 PM
GOOCH-JDM-ITR's Avatar
Default Re: Tires rotated, now car pulls left? (Track rat)
it really depends on how the tires were worn origianlly.
Mine always pulls diferent after a rotation
Old 10-20-2004, 01:30 PM
DC2fanboy's Avatar
I think as long as it doesn't pull hard, (i.e. you can't stay in your lane for like 100m or something) it is probably a wear issue, especially since you've checked your tire pressure.
I've had an incident where I had been riding the side wall of my tires for a while (due to low pressure/leakage during storage) and I ended up blowing it out when I noticed and tried to pump it to the correct pressure (it had been pulling left on the highway).
Do you know how the rotated the tires?
I always check tire pressure meticulously now... especially after changing rims... live and learn...
Old 10-20-2004, 06:09 PM
Bbasso's Avatar
Do you have directional tires? Did the shop follow the recommended tire swap pattern for directional tires?
Old 10-20-2004, 06:19 PM
Runnerdown's Avatar
Tires do that all the time. Swap them side to side and see if it goes away.
Old 10-20-2004, 08:35 PM
I fry gay turkeys
Honduh Chicken's Avatar
Default Re: (Runnerdown)
Did it used to pull to the right?
Old 10-20-2004, 09:29 PM
Bryce's Avatar
Default Re: (Honduh Chicken)
Mine have done that before, cars lowered and i get camber wear. try swapping the fronts to the opposite side.
361 accord
04-09-2007 02:34 PM
AznMTboy
08-26-2005 06:25 AM
Kyles ej1
17
09-20-2004 05:49 PM
sshaikh01
23
04-07-2003 06:20 PM
Quick Reply: Tires rotated, now car pulls left?
