SMSP high flow cat
Re: SMSP high flow cat (LH-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 »</TD></TR><TR><TD CLASS="quote">is his username on here SMSP???
Yes
Yes
as long as the header you have on is stock or USDM length, then it should bolt right up....
SMSP cats come in different lengths also, so you can get a 12 inch or 16 inch...universal ones, or you can get a direct fit...
With the direct fits, you dont have the choice of bigger inlet and outlet diameters, you just get the stock 2.25 inch.
since the t1r exhaust 2.5 inch diameter piping, you will need to get a cat that will have either a 2.25 inlet/2.5 outlet ( if you have stock header) or you have to order a 2.5 inch inlet/2.5 outlet ( if you have an aftermarket header with a 2.5 inch collector)
The length of the cat would depend on the header strictly...
Re: (LH-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 »</TD></TR><TR><TD CLASS="quote">Once i install this stuff am i going to get a CEL because of the new exhaust.
If so what should the code be??</TD></TR></TABLE>
You shouldn't get a CEL your exhaust? Just make sure the the cat is for an ODBII vehicle with an O2 sensor bung before and after the cat.
Re: (eluam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluam »</TD></TR><TR><TD CLASS="quote">I've got a SMSP high flow cat and love it. </TD></TR></TABLE>
Re: (LH-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 »</TD></TR><TR><TD CLASS="quote">I talked to Dave at SMSP he got me all set up.
now about the o2 sensor????</TD></TR></TABLE>
On ODBII vehicles, there are two O2 sensors. One before the cat, and one post cat. When you order the cat from Dave, specify that you will need both bungs.
Re: (coolhandluke)
K i will do that. Thanks for your help man.
Also i saw that you said that the T1R 63s was discontinued. I also heard that but i see it all over.
Examples-http://jhpusa.com/store/pc/viewPrd.asp?idcategory=353&idproduct=1393
http://www.aj-racing.com/catal...age=2
and a couple others
and a couple others
citanest
03-07-2002 10:52 AM
