My experience - steel wool in oil catch can
Old 09-06-2004, 12:26 PM
[HrZn]4life's Avatar
Default steel wool????
Anyways, a few weeks ago I stuffed some steel wool into my "unbaffled" oil catch can, with the idea that the steel wool would help filter out the blow by gases. Much to my surprise my car feels like it is running a lot smoother and healthier. My car burns a lot of oil and blow by levels are pretty bad, so I'm assuming that the wool is helping with keeping my combustion a bit more efficient, although my rings are still shot..... Just thought I'd share this with you guys; anybody else experience anything like this?
Old 09-06-2004, 01:38 PM
silver comet's Avatar
Default Re: steel wool???? ([HrZn]4life)
hey man what's going on? We should get another meet goin
Old 09-06-2004, 03:43 PM
Default Re: steel wool???? (silver comet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver comet &raquo;</TD></TR><TR><TD CLASS="quote">hey man what's going on? We should get another meet goin </TD></TR></TABLE>
definitely; there's a meet/track day out at Infineon Raceway next weekend but i'm not gonna make it anymore. We should set something up like a BBQ before Winter comes...
Old 09-06-2004, 03:59 PM
Tweakmeister's Avatar
I was always concerned of little metal flakes getting in the engine since most steel wool is so...flakey.
I guess it works fine?!?
Old 09-06-2004, 04:23 PM
Default Re: steel wool???? (Tweakmeister)
I was concerned about the same thing but the steel wool method is widely recommended so I gave it a shot. Even C-speedracing.com suggests to use it too.
http://www.c-speedracing.com/h...n.php
Car felt a lot better, so I guess nothing bad can be happening....
Old 09-06-2004, 05:46 PM
Nishant's Avatar
don't jinx it
Old 09-06-2004, 06:56 PM
It's probably fine. It's the right consistency, you just gotta make sure it won't come apart.
I'm running the tiny Jaz plastic thing so I'd have to drill the top just to fit in the little pieces. I catch about a tablespoon a month
Old 09-06-2004, 07:37 PM
R you serious's Avatar
doesnt the cusco can come with steel wool?
Old 09-06-2004, 07:47 PM
Bbasso's Avatar
How much did the catch can cost you for the parts and install?
I gotta try something, the car is just using too much oil...
Old 09-07-2004, 12:37 AM
Default Re: steel wool???? (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">doesnt the cusco can come with steel wool?</TD></TR></TABLE>
I'm not sure...according to the cspeed article they had to add it....
Old 09-07-2004, 12:41 AM
Default Re: steel wool???? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">How much did the catch can cost you for the parts and install?
I gotta try something, the car is just using too much oil... </TD></TR></TABLE>
I'm using a generic arospeed oil catch can that's unbaffled. It was only ~30.00 dollars and you just install it yourself; just gotta find a good location. I found a mounting point in between my coolant overflow reservoir and intake but the catch isn't mounted completely upright. I picked up a small hawker battery that's going to free up some space on the firewall and that's where i'm going to mount it now.
Old 09-07-2004, 03:08 AM
mr_ben's Avatar
If you are worried about the degriadation (sp?) then why not try..
This is what I use and it works just as good IMO
or
For those who can't work them out (there may be some!! ) They are house metal scrubbers, made out of stainless steel.
Old 09-07-2004, 05:13 AM
CW-ITR's Avatar
Default Re: (mr_ben)
Haha! I call those stainless dog gone bad cookies.
Old 09-07-2004, 05:16 AM
Bbasso's Avatar
thanks
Old 09-07-2004, 09:09 AM
vtec.dc2's Avatar
how do you have your catch can setup? if you're already have oil consumption due to bad seals, catch can won't help with that.. but its still good to run..
i always though baffled is when you want to run from valve cover to catch can then inside intake.. i just run it open. then another setup would be from pcv valve to unbaffled catch can with no breather and to IM. - what i have.
Old 09-07-2004, 06:50 PM
go to Jegs and find the small Jaz catch can (not the big one). It's like $45 and I glued (my favorite donkey snot, GE Silicone II) a deer park water bottle cap on top of it
I like the Jaz because it's small, black, and fits on the passenger side electronics bracket (zip ties) then I can just drain the contents out of the bottom via the nozzle.
Old 10-06-2005, 01:54 PM
tdo
tdo's Avatar
i know this is a year old but what grit steel wool did you guys use?
Old 10-06-2005, 03:30 PM
.water's Avatar
Default Re: steel wool???? (tdo)
holy cow old thread back on live...
steel wool is not that great idea, since it can go into your engine little by little....
Old 10-06-2005, 06:16 PM
RagingAngel's Avatar
Default Re: steel wool???? (JunkyDC2)
As mentioned above, use stainless steel scrubbers instead....
Old 10-07-2005, 12:04 AM
tdo
tdo's Avatar
Default Re: steel wool???? (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">As mentioned above, use stainless steel scrubbers instead....
these wont flake like the steel wool?
Old 10-07-2005, 12:36 AM
less chance it will.
others have used a "ball/chain" setup....take a look at a table lamp or any type of home fixture that requires you to pull on a ball and chain link to turn the light on/off.
Or it can also be found on army dogtags.
Old 10-13-2005, 07:23 PM
tdo
tdo's Avatar
anyone know if theses are cool? will these flake?
its "Quickie brand" Wire Mesh Scourers
Old 10-13-2005, 08:19 PM
Those look okay.
OMG, I said "donkey snot" a year ago
Old 10-13-2005, 08:43 PM
zxander's Avatar
good thinkin
Old 10-15-2005, 03:10 AM
Ausmith's Avatar
Are you running a drain-back line to the intake or block passage?
I could see a possible advantage if you are running a closed system that basically places the catch can inside the stock system - like Endyn does it. If you aren't then there will be no benefit to putting any sort of baffle in the can.
Quick Reply: My experience - steel wool in oil catch can
