jdm itr header vs dc jdm itr
Old 03-17-2003, 03:33 PM
Spoon_Nazi's Avatar
Default jdm itr header vs dc jdm itr
its going to be for my friend's itr, we were just wandering which one most itr drivers preferred and give reasons why? ie, more power, higher top end, etc. thanks
and yes i searched, but didnt come up with any specifics
Old 03-17-2003, 03:38 PM
AllMotorMadness's Avatar
Default Re: jdm itr header vs dc jdm itr (Spoon_Nazi)
the both work the same.
Old 03-17-2003, 03:45 PM
SurferX's Avatar
There's no point in comparing those headers, they're almost the same thing. I say DC just because it's lighter.
Old 03-17-2003, 03:46 PM
Spoon_Nazi's Avatar
Default Re: jdm itr header vs dc jdm itr (AllMotorMadness)
are they really??
does anyone have dyno sheets of both on an itr motor...
YellowR2000x2's Avatar
check the great header test, going by that they seem to be the same but the dc appears to be a little more choppy through the power band, jdm one seemed to be a little smoother.
Old 03-17-2003, 03:47 PM
Spoon_Nazi's Avatar
Default Re: jdm itr header vs dc jdm itr (SurferX)
kay thanks
no need for further discussion than
Old 03-17-2003, 03:54 PM
B2FiNiTY's Avatar
I would think ground clearance would play a big role in choosing one.
Old 03-17-2003, 03:56 PM
py1188's Avatar
Default Re: jdm itr header vs dc jdm itr (B2FiNiTY)
How much better is the ground clearance on the OEM JDM as opposed to the JDM DC??
magic hat #9's Avatar
performance-wise they have been shown to be quite similar.
jdm dc pros (vs jdm oem): lighter, cheaper, not rust colored
jdm dc cons (vs jdm oem): more prone to defects and cracking (dc sports ), no heat shields available (for stock look to hide what ya brung), less durable, dents easier (not much ground clearance down there)
Old 03-17-2003, 04:00 PM
Maximus's Avatar
The dc header is from the same design as the jdm itr one. The big difference between them is the price. You can get a jdm dc header for $295 or a jdm itr one that costs $375. Take into consideration that you can use factory headshields with the oem header.
In the Great Header Test, the jdm dc header made 2 peak whp more than the jdm itr. http://bob123e.tripod.com/thegreatheadertest/
[Modified by Maximus, 9:25 AM 3/18/2003]
Old 03-17-2003, 04:04 PM
ITR#JohnBasedow's Avatar
Default Re: jdm itr header vs dc jdm itr (Maximus)
what other mods were on that car besides the jdm and dc header?
see...dc bumpy..not good methinks, jdm alot smoother, both torque and hp...
exhaust and intake i believe as well as a modified cat for the JDM header fitment.
[Modified by YellowR2000x2, 1:05 AM 3/18/2003]
Spoon_Nazi's Avatar
The dc header is from the same design as the jdm itr one. The big difference between them is the price. You can get a jdm itr header for $295 or a jdm itr one that costs $375. Take into consideration that you can use factory headshields with the oem header.
which one costs more?
Old 03-17-2003, 04:10 PM
jdm dc is cheaper.
what are ground clearances for each header?
Old 03-17-2003, 04:24 PM
SurferX's Avatar
Default Re: jdm itr header vs dc jdm itr (magic hat #9)
The JDM ITR has slightly better ground clearance but not by much. They both hange pretty low.
Old 03-17-2003, 04:33 PM
Eric R's Avatar
I have the JDM DC in SS. I'm very pleased with it.
Now, comparing with the JDM stock, don't you have to smooth the inner weldings by the flange in order to perform better? I didn't have to touch my DC. I came as smooth as a baby butt chick.
Old 03-17-2003, 04:42 PM
big strong guy
rainmanEK's Avatar
Default Re: jdm itr header vs dc jdm itr (Tweety R)
I dont think You can Even Put the two in the same Class, Look at the Size of the Primarys!
The JDM ITR = Stock Header
DC JDM ITR = Aftermarket Header
Though the JDM ITR is a nice header if you want to Keep A stock Apperance!
But I Will bet My life the DC will out perform the JDM ITR on a Modified Engine!
Eric
Old 03-18-2003, 12:25 AM
Maximus's Avatar
Fixed my earlier post
Old 03-18-2003, 12:40 AM
itr-j's Avatar
both are not bad pieces
Old 03-18-2003, 01:05 AM
Ex-ITR5874's Avatar
Default Re: jdm itr header vs dc jdm itr (rainmanEK)
Hope, this helps..
Get a Toda
Cesare1987
09-05-2005 04:16 PM
InfamousRS
04-24-2002 08:22 PM
jg
07-14-2001 04:40 AM
Quick Reply: jdm itr header vs dc jdm itr
