how often should I change spark plugs?
Old 11-08-2002, 01:10 PM
jdmspoonitr's Avatar
Default how often should I change spark plugs?
right now i have 15,000 miles. has been tracked a couple times at most. I probably need to change them, but is there anything else I need to change along with the plugs??? And secondly I think I saw a past post that recommended the stock plugs over aftermarket. Just checking. thanks for all the help guys.
Old 11-08-2002, 02:12 PM
Tweakmeister's Avatar
Default Re: how often should I change spark plugs? (jdmspoonitr)
I changed mine around 30k and noticed a big difference. At the very least make sure yours are gapped correctly.
I replaced mine with BERU Silverstone S3F
Old 11-08-2002, 02:26 PM
IntegraGSR23's Avatar
Default Re: how often should I change spark plugs? (Tweakmeister)
Where did you pick those up at? and how much??
Old 11-08-2002, 02:32 PM
Nameless RB26's Avatar
Default Re: how often should I change spark plugs? (IntegraGSR23)
I clean my spark plugs with a high grit sandpaper, and wipe them off good with some gas.
That's only when I'm bored though. I think stock plugs should be replaced @60k miles. Platinums are about 20k I believe..
Old 11-08-2002, 03:02 PM
Bbasso's Avatar
Default Re: how often should I change spark plugs? (Nameless)
if your putting sand paper to the spark plug you might be sanding off the platnim finish... and also making the gap bigger...
Just use chemicals or buy new- for .99 I buy Champion RC12MC4 they last 7-10k miles and work good.
[Modified by Bbasso, 7:03 PM 11/8/2002]
Old 11-08-2002, 03:31 PM
I bought my Silverstones from Nology...but I've since found cheaper (I just forget where )
I would recommend shopping around a bit.
http://www.hogens.com/car/default.ph...lugs/index.php
Old 11-08-2002, 05:48 PM
Dirt's Avatar
everyday just like w33d
Old 11-08-2002, 07:39 PM
SUPERAUTOBACS's Avatar
Default Re: how often should I change spark plugs? (BrewCityR)
Does anyone know the benefits of using copper plugs? Any?
I remember reading a loong time ago that copper plugs perform better (in what way, i cant remember) but dont last nearly as long as platinum tipped plugs.
Old 11-08-2002, 11:14 PM
vtec.dc2's Avatar
stock plugs is all i use.. - with stock ecu its easy to run healthy to 40K miles, but good idea to have them checked at least every 30K... with aftermarket ecu/ignition/changed timing - its a good idea to cut it down to 10-15K..
also check dist. rotor - make sure its not fried or anything.. -
maybe distribur cap - should be fine at 15K
Old 11-09-2002, 06:26 PM
Teepo's Avatar
Default Re: how often should I change spark plugs? (vtec.dc2)
NGK #2380 ......7 platinums baby
lawrencelomanon
Honda CR-V & Element
11-15-2017 10:37 AM
mrtrinh
Honda Civic (2001 - 2005)
02-19-2008 05:37 PM
FG_Coupe
Honda Civic (2006 - 2015)
10-26-2007 05:29 PM
Nocturnal
03-28-2003 05:25 PM
2k1 GSR
01-12-2003 02:33 AM
Quick Reply: how often should I change spark plugs?
