Help with clutch parts needed
http://www.acuraautomotiveparts.net/...RQUE+CONVERTER
What parts are needed to replace the clutch? I will by a lightened freewheel but may stay with the stock clutch. Do all I need is the clutch disc and release bearing?
Re: Help with clutch parts needed (davidnyc)
i would also check your pee pee, incase it was warped or damaged in any way
asides that, the throw out bearing should be replaced and a clutch tool should come along with the clutch hopefully
asides that only other thing is i would make sure that the flywheel you get has a resurfaceable face.
[Modified by Soup ****, 8:02 PM 12/22/2002]
Re: Help with clutch parts needed (rodney)
Rodney, you are definitely my technical advisor.
I was just roaming website and wondering. My assumption was pilot bearing and throw out bearing, clutch disk, and flywheel??? I think the pressure plate needs to be changed only if you want to upgrade to a stronger plate.
Things you "should" do while you have the tranny out...
replace: clutch disc
pressure plate
throwout bearing
pilot bearing
3 qts of Honda MTL
if re-using stock flywheel have it resurfaced at a local machine shop
Also while you're there check the CV boots for rips or excess wear. Happy Wrenching
pressure plate
throwout bearing
pilot bearing
3 qts of Honda MTL
ericlee303
09-08-2007 11:34 AM
