Gapping of spark plugs
Old 07-24-2003, 10:09 PM
itr817's Avatar
Default Gapping of spark plugs
I just got a new set of NGK spark plugs what is the proper gapping setting?
Old 07-24-2003, 10:21 PM
Boges's Avatar
Default Re: Gapping of spark plugs (itr817)
1.3mm
Old 07-24-2003, 10:23 PM
itr817's Avatar
Default Re: Gapping of spark plugs (Boges)
thank you
Old 07-24-2003, 10:25 PM
IN VTEC's Avatar
What engine? Mods?
Old 07-24-2003, 11:32 PM
HYREV2NR's Avatar
I'm not sure if your running standard core plugs or plats. But I will tell you that I run standard core NGK's in my R. If you like, try these NGK's... stock# 1273. They are one heat range cooler plug than stock & they really help cut down the risk of detonation. 7 bucks is not bad for a set of plugs!
Old 07-26-2003, 11:29 AM
B2FiNiTY's Avatar
Stock is 1.1mm Heat range of 6.
Old 07-26-2003, 06:10 PM
Boges's Avatar
Default Re: Gapping of spark plugs (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Stock is 1.1mm Heat range of 6.</TD></TR></TABLE>My mistake, GSR is the only B series with 1.3, all others are 1.1 i believe.
xiaogou
11-21-2007 01:37 AM
rockenuptown
06-26-2007 02:48 PM
2001accord
07-07-2005 03:24 PM
TeGGY_LS
01-20-2004 02:05 AM
dc2lun
01-13-2004 01:41 PM
Quick Reply: Gapping of spark plugs
