Clicking noise coming from inside steering column?
Old 04-19-2007, 06:37 PM
Damon Reeves's Avatar
Default Clicking noise coming from inside steering column?
Took my car to the shop today..to check out the clicking...at first I assumed it was the axles...shop claimed they were fine.
Now my question is, has anyone encountered this similar problem? steering wheel clicking when turning the steering wheel?
Old 04-19-2007, 06:43 PM
vtec.dc2's Avatar
Default Re: Clicking noise coming from inside steering column? (Damon Reeves)
does your steering wheel lock if you try to move the wheel with key removed?? more than likely has somethign to do with that mechanism
Old 04-19-2007, 07:04 PM
Default Re: Clicking noise coming from inside steering column? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">does your steering wheel lock if you try to move the wheel with key removed?? more than likely has somethign to do with that mechanism</TD></TR></TABLE>
Yes my steering wheel locks...when the key is removed.
Old 04-20-2007, 04:49 AM
Runarh's Avatar
I have/had the same clicking from the steeringwheel/column. Only came when i turned the wheel fast and only right after starting the car (cold).
Don't know what it is, but now its a while since last time i heard it.
Old 12-26-2007, 10:58 AM
b16a4's Avatar
Default Re: Clicking noise coming from inside steering column? (Runarh)
did you ever figure it out?
Old 12-26-2007, 03:51 PM
teg97's Avatar
Default Re: Clicking noise coming from inside steering column? (b16a4)
it sounds like your abs ring ..the plastic may be broken and clicks when you turn the wheel.
Ur 2 Slow 4 J
11-01-2015 02:25 PM
civicdelsol33
12-06-2011 05:09 AM
pr0phet
11-10-2005 09:19 PM
b18c-1
10-01-2005 08:48 PM
Quick Reply: Clicking noise coming from inside steering column?
