CEL / MIL # 40 with Hondata any thoughts?
So recently I've had the Check Engine Light come on while driving, when I turn the car off and turn it back on the CEL goes away. Now when I short the connector and check to see what code it is I have a # 40 come up...but what in the hell is CEL # 40?
Even if I reset the ECU, the code comes back within a day. I've noticed that this code only comes on when I drive the car after it's been sitting for a while. If I drive the car for a while, then turn it off, then start it again and drive the car the CEL doens't come back on. I have a '01 Type-R running an S200 with a Hondata modified P06(P28) ecu.
Anyone have a clue to this?
Austin
Austin
Re: CEL / MIL # 40 with Hondata any thoughts? (Austin)
Maybe check the sequence of lights again.
And use this for reference:
http://www.londonautoclub.org/...s.htm
Re: CEL / MIL # 40 with Hondata any thoughts? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">do you have laptop hooked up to pull the code? i thought thats the only way to pull the code on our cars.</TD></TR></TABLE>
You are wrong.
You are wrong.
Re: CEL / MIL # 40 with Hondata any thoughts? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R »</TD></TR><TR><TD CLASS="quote">Maybe check the sequence of lights again.
http://www.londonautoclub.org/...s.htm</TD></TR></TABLE>
Thanks BPR...I've pulled this same code 5 different times, I even went back to check the code when I found that #40 didn't exist.
Austin
Austin
You sure it's not code #4? If you are really pulling a code #40 (4 long blinks), there is a problem within the ECU or the Hondata. If you have datalogging, you could run with the datalogging going, and then replay the event when the code trips. Just examine all of the sensors, and look for anything unusual.
Re: CEL / MIL # 40 with Hondata any thoughts? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">You sure it's not code #4? If you are really pulling a code #40 (4 long blinks), there is a problem within the ECU or the Hondata. If you have datalogging, you could run with the datalogging going, and then replay the event when the code trips. Just examine all of the sensors, and look for anything unusual.</TD></TR></TABLE>
Yep...quite sure that it was a #40, pulled it 8+ times. After speaking with Hondata they think that right after start something is going on with the short/long term fuel trim. If I start the car, run it for a minute, turn it off then drive away the CEL doesn't come on.
Austin
Austin
krisfnbs
05-23-2008 06:42 AM
Zaraki
03-31-2008 08:26 PM
