Old 03-31-2015, 08:43 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Brake Guides
Print Wikipost
Brakes squealing after pad change
Old 12-29-2009, 03:58 AM
97CWITR's Avatar
Default Brakes squealing after pad change
Put new hawk hp+ pads on the R and now they make a terrible squealing noise at low speed.
I inspected the rotors and they still look good. I don't hear any noise above 10mph, but any breaking below this, I get a terrible noise.
Ive changed my brakes many times before and never had this issue...
Maybe the pads are dragging slightly on the rotors?
Old 12-29-2009, 09:28 AM
Tekkaboy's Avatar
Default Re: Brakes squealing after pad change
You can apply some 'disc brake quiet' to the pad shims.
Also, make sure you lubed the caliper slider pin with high-temp grease.
Old 12-29-2009, 10:58 AM
jdm_dc_fan's Avatar
Location: "That one guy with that one car" Kennewick WA
According to hawk they're gonna make a little bit of noise. I dont know how severe your situation is though. When I had hawk hps' on my s2k I broke them in according to hawks instructions and they were quiet as stock. Hope that helps.
Old 12-29-2009, 11:05 AM
97CWITR's Avatar
Ive been looking around, and that seems like it could be the problem...
Will any high temp grease do?
If you heard the noise you'd know! lol
Old 12-29-2009, 11:23 AM
Wai
ProFunction/GT Motoring
Wai's Avatar
Does it squeal when your foot is off the brakes at low speed? Or when you applied the brakes at low speed?
If it's the former, most likely you have brake dust or debris trapped somewhere when you changed the pads. Spraying it with brake cleaner should help. If it's the latter, then I guess it's just the properties of the pads (I haven't used them personally so I can't say for sure).
Old 12-29-2009, 11:29 AM
97CWITR's Avatar
It's both.
Spraying the brake pad directly with brake cleaner? That doesn't sound good...
It was squealing a bit before the pad change over as well.
Old 12-29-2009, 02:55 PM
H-T Order of Merit
nsxtasy's Avatar
Then it's likely to be some kind of debris or lack of lubrication, rather than the pads themselves.
I've used many sets of the Hawk HP+ and mine don't squeal at all.
Old 12-29-2009, 05:43 PM
Wai
Wai's Avatar
It's both.
Brake cleaner evaporates quickly. I don't see or haven't encountered any problem spraying it to the pad or rotor surface directly. Just keep it away from the paint and plastic/rubber.
Old 12-29-2009, 06:25 PM
H-T Order of Merit
nsxtasy's Avatar
Go at the calipers with a wire brush to remove the dirt and dust...
Old 12-29-2009, 06:41 PM
97CWITR's Avatar
Thanks again for the advice. Im going to give it a shot thursday afternoon hopefully. The car is going to sit until then.
Old 12-29-2009, 06:42 PM
MiG-21 superfan
builthatch's Avatar
re: the pad shims...
were the shims on those pads that composite material that is sorta like a rubberized thin kevlar? i just installed a set of hawk ceramic pads on my wife's si and these were the first i've every installed with neat damper shims like that.
if they weren't...then i suggest putting disc brake quiet on the shims. it's not lube, it's a somewhat tacky...sorta rubbery coating that dampens the pad harmonics.
but you do mention that it was doing this before the change too...hmm
when it's making the noise...does it change when you turn the steering wheel while it's making the noise? i'm curious if there is something in-between the backing plate and the rotor, or the backing plate itself is just BARELY touching it...i've seen that many times.
this can happen and can mimic many other brake issue sounds.
Old 12-30-2009, 06:26 AM
97CWITR's Avatar
There were no pad shims provided in the box. Im not using any shims right now.
It does make the noise while turning the wheel as well. Which backing plate are you refering too?
Old 12-30-2009, 06:54 AM
Tweakmeister's Avatar
I just put a small dab of grease (any will do) on the backs on the pads where they meet the caliper.
Old 12-30-2009, 07:09 AM
MiG-21 superfan
builthatch's Avatar
the thin metal plate behind the rotor. sometimes things can get lodged there, or it can bend ever so slightly touching the rotor in certain instances making various types of noises.
re: shims, i can honestly say i've never NOT used shims, either stocks ones with disc brake quiet, or like i said sometimes they have included ones that are a rubbery kevlar type (textured tiny weave), like the hawk ceramics i just installed.
did the pads before this have shims?
Old 12-30-2009, 08:03 AM
H-T Order of Merit
nsxtasy's Avatar
I've used pads without the metal shims without problems. But I do use the goopy stuff applied to the back of the brake pad.
Old 12-30-2009, 08:22 AM
Tekkaboy's Avatar
Just as a note, the caliper pin not being lubed is probably not the cause of the noise, but I just mentioned that it should be lubed because most people forget to do it.
But yes, any high temp grease should do. Honda sells a little ~2oz bottle for like $12 which is a rip-off. I use this stuff since it's rated up to 2800 F:
http://www.amazon.com/Permatex-24125...gy_auto_text_b
The regular kind works fine too:
http://www.amazon.com/Permatex-24115.../dp/B000HBGKH4
Old 01-01-2010, 06:13 PM
97CWITR's Avatar
Got around to working on the R today.
Made sure everything was cleaned, and greased up this time. I had new rotors so I figured while I had everything apart again, I might as well install them too.
The sliders did have some grease on them, but I added more, and its nice and quiet again!
Because I changed the rotors at the same time i can't say for certain that it was one or the other...Im just happy it isn't making noises anymore.
Thanks again for all your help ITR folk!
Old 01-07-2010, 05:59 PM
97CWITR's Avatar
The noise started again...
Got the local acura dealer to check it out and they said the pads were really cheap (hawk hp+) and were causing the squealing. Wasn't impressed by that answer.
I didn't grease between the pad and the caliper with brake quiet or grease, and that's the last thing it could be. The calipers are operating as they should apparently.
Im going to try it again and see if it works.
OT...while at the dealer I got some horrible leakdown and compression numbers...more money...
They wanted $10,000 for a re-build!!!!!! LOL
Old 01-08-2010, 01:57 PM
get RIGHT's Avatar
All grease is not the same. Look for Anti squeal grease when you go to the parts store. just wear gloves when you apply it. That stuff gets everywhere and doesnt come off clothes very easy.
Old 01-08-2010, 04:24 PM
MiG-21 superfan
builthatch's Avatar
doh, man, you can't say we didn't talk about this! haha...
yeah, the typical disc brake quiet i think is made my CRC and is a red tacky stuff. you just put the pads face down and spray a quick spray on the back. let it sit for a second to set up, and at that point it shouldn't be messy at all, just tacky.
like i said, i've never had this issue, ever, and used OE shims or the type that comes on the pads already (ie hawk ceramic)...and when using regular shims, i always use regular disc brake quiet.
and that acura dealer gave you a few reasons why you should never ever step foot on their property again. i HATE dealerships like that...
maxogsr
Honda Civic (2001 - 2005)
01-30-2010 09:21 PM
icebluecivic21
04-29-2008 10:56 PM
Landshark68
04-20-2007 10:01 AM
dohc_profile
01-30-2007 09:24 AM
mickey513
02-04-2003 09:36 PM
Quick Reply: Brakes squealing after pad change
