Anyone ever replace the rear hub/bearing assembly?
Old 06-24-2003, 12:06 AM
New User
BrandonClaps's Avatar
Default Anyone ever replace the rear hub/bearing assembly?
Anyone ever replace the rear hub/bearing assembly? Is it pressed on, or when u removed the spindle nut it will just pull off?
Old 06-24-2003, 12:34 AM
JustLooking's Avatar
Default Re: Anyone ever replace the rear hub/bearing assembly? (BrandonClaps)
The hub assembly is easy to replace. Take off the brake caliper and rotor. Remove the dust cap and then remove I believe the 32mm bolt and the hub comes right off.
Old 06-24-2003, 01:32 AM
sgT
sgT's Avatar
the new rear hub should come with a new bearing on it so replacement is pretty much bolt on.
Old 06-24-2003, 03:27 AM
gblaue's Avatar
Default Re: Anyone ever replace the rear hub/bearing assembly? (sgT)
One important note worth noting. Tighten to proper torque spec, or you'll be replacing them again prematurely.
Old 06-24-2003, 04:17 AM
sgT
sgT's Avatar
Default Re: Anyone ever replace the rear hub/bearing assembly? (00ITR#756)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ITR#756 &raquo;</TD></TR><TR><TD CLASS="quote">One important note worth noting. Tighten to proper torque spec, or you'll be replacing them again prematurely.</TD></TR></TABLE>
Never had that problem before.
Old 06-24-2003, 04:24 AM
Track rat's Avatar
Be preparred to shell out some $$ and it may not be on the shelf since it is an "ITR only" part. I paid $134 for one and had to wait 2 weeks for it.
Old 06-24-2003, 01:13 PM
New User
Default Re: Anyone ever replace the rear hub/bearing assembly? (Track rat)
they have the part instock actually, it's $133
but has anyone ACTUALLY done this?
Old 06-24-2003, 01:34 PM
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">but has anyone ACTUALLY done this?</TD></TR></TABLE>
What, you need more than two people to tell you?
Old 06-24-2003, 01:35 PM
New User
Default Re: Anyone ever replace the rear hub/bearing assembly? (.RJ)
i just want to know if somene has actually completed it, without people looking at there helms or something and saying it'll just pop off
Old 06-24-2003, 01:37 PM
Cosworth's Avatar
Or, you could buy the whole rear trailing arm for a few more $$ with everything assembled.
.RJ
.RJ's Avatar
I would trust what steve has to say.
With anything to do w/ hubs/bearings the BFH and BFD (Big farking drift) are your friends.
Old 06-24-2003, 02:10 PM
Track rat's Avatar
I've actually replaced them...very easy, bearing usually slides off the spindle with the hub:
Quote from Justlooking:
Old 06-25-2003, 11:21 AM
gblaue's Avatar
Had that problem with my 93 GS-R. Because the inner race is 2 pieces, overtightening will cause them to wear prematurely.
Old 06-25-2003, 02:18 PM
davidnyc's Avatar
I have had to replace my rear wheel studs (needed longer studs for spacers) so I had to take the rear hub off. Once the car is jacked up and the wheels are off, it takes about 1/2 hour to take the hub apart. It is very simple. The cap on the hub is somewhat annoying, but not too hard to get off if you have a nice flat head screw driver.
bw77
12-26-2014 05:41 AM
DC4_Dad
10-24-2014 06:06 PM
bward
07-17-2006 07:40 AM
jdm*Stars
10
06-20-2005 01:45 PM
jasonb
06-22-2002 07:17 AM
Quick Reply: Anyone ever replace the rear hub/bearing assembly?
