ABS 51 code
ABS 51 code
ABS light came on today. I checked for codes and it`s just one code - 51 motor lock. I erased DTC and ABS light lights up again after a few meters.
Did somebody had the same problem and had to replace the modulator unit? It`s a first time for me to hear that the modulator unit had to be replaced.
I'm bored and tried searching but there are so many...
Use ABS codes as the search criteria, archived content and specifically in the ITR forum... Oh and use the post bodies, not thread topics.
HTH.
HTH.
Re: ABS 51 code (urosch)
DTC 51: Motor Lock
-When the vehicle starts, the ABS indicator comes on.
-With the SCS service connector connected, DTC 51 is indicated
Problem verification
1. Erase the DTC.
2. Test-Drive the vehicle at 6mph (10km/h) or more
Does the ABS indicator come on and is the DTC 51 indicated?
Yes -> Replace the modulator unit.
No -> The system is OK at this time.
1. Erase the DTC.
Re: ABS 51 code (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">DTC 51: Motor Lock
1. Erase the DTC.
No -> The system is OK at this time.</TD></TR></TABLE>
I`ve done that. Just want to know if there is another way to solve this problem.
1. Erase the DTC.
