will a vtec solenoid from a D16 work for a B17 GSR
Old 08-18-2007, 06:35 AM
4crx20's Avatar
Location: desert hot springs, california, united states
Default will a vtec solenoid from a D16 work for a B17 GSR
I bought a used b17 GSR head to build an lsv. I'm looking for a vtec solenoid.Will any vtec solenoid work?
Old 08-18-2007, 06:40 AM
Jet Life Til' The Next Life
Byaaah!'s Avatar
Default Re: will a vtec solenoid from a D16 work for a B17 GSR (4crx20)
I think it's the plug thats different...
Old 08-18-2007, 07:03 AM
4crx20's Avatar
Default Re: will a vtec solenoid from a D16 work for a B17 GSR (Project95LS-VTEC (G))
if its just a different plug,that shouldn't be a problem.do you know if they are shaped the same,or if the dohc solenoid operates at a higher oil pressure.the reason I am thinking of oil pressure,DOHC vtec pushes 2 cams sohc only 1
Old 08-18-2007, 09:24 AM
duggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx20 &raquo;</TD></TR><TR><TD CLASS="quote">if its just a different plug,that shouldn't be a problem.do you know if they are shaped the same,or if the dohc solenoid operates at a higher oil pressure.the reason I am thinking of oil pressure,DOHC vtec pushes 2 cams sohc only 1</TD></TR></TABLE>
It does not matter. The pressure solenoid works on just that, detecting pressure and activating VTEC.
JSpekBB4
10-30-2007 10:23 PM
20CiViCSi00
11-14-2006 02:38 PM
vtecn8ive
22
08-03-2005 01:06 PM
Nsane1
06-12-2004 04:47 PM
Thundersquid
10-01-2003 08:40 AM
Quick Reply: will a vtec solenoid from a D16 work for a B17 GSR
