why do my new brakes grind? :(
i have a '95 GS-R, and have had the following done in the past year:
*new rotors front and rear in december
*new master cylinder in december
*new pads, front and rear last month
when i come to a stop, i hear grinding and can feel it in the pedal. it gets worse when the brakes are hot or if i try a sudden stop.
i brought it back to the shop, but they say everything is ok.
could it be the pads they used? or possibly a stuck caliper? the car stops fine, but the noise/friction is annoying.
thx
thx
Re: why do my new brakes grind? :( (RCLGSR)
spin the wheel while the car is up on stands and see if you notice anything. at least that was the problem with mine
Re: why do my new brakes grind? :( (In7egrity)
What type of pads?
You should here my Hawk HP+'s sometimes, they grind like a motha..
But OHHHHH once they're nice and toasty they can suck my eyeballs out...
Re: why do my new brakes grind? :( (AkiraLite)
One night my brakes began to grind really badly, sounded like metal to metal contact, I jumped out and got a flash light, but couldn't see anything wrong with them. I got into the car and drove down the block and the grinding stopped, and never came back since last autocross event but it went away after driving a few feet.
I have hawk hps.
I have hawk hps.
I have a 95 and I had to replace all the same stuff you did front pads, rear pads, front and rear rotors, and did my master cyl 2 months ago.. anyway what type of pads are you using? my Hawk HPS and Brembo blanks have a little noise when their still cold after a few stops the noise goes away... but when their cold/sitting overnite they tend to grind and make some noise more than usual... it stops great so I just ignore it...
Re: why do my new brakes grind? :( (GSRaCeRbOI)
thanks for the replies everyone.
i have axxis pads and some 'oem' grade rotors. the car stops fine, no fade either.
mr.abourque
09-03-2010 04:55 PM
benSC
13
11-24-2004 07:12 AM
