Flywheel bolts......sheard
Old 09-03-2008, 11:39 AM
Ricextacy's Avatar
Default Flywheel bolts......sheard
I heard a roaring noise in between shifting, and found out it was my "throwout bearing" i immediately drove it home "30 miles away" 1/2 a mile away from my home it started to RUMBLE pretty hard, towed it home...
jacked up the car and got started removing the transmission.
and saw this..
The Starter was chipped up pretty good. but it still spins..
and than i saw this...
heres a pic of the block..that is suppose to be holding the Flywheel, clutch and Pressure plate
now i gotta find a way to take off the broken bolts that are suppose to hold the flywheel to the crankshaft, Honda parts unlimited are charging $3.25 a bolt and the throwout bearing is gonna cost me $45. which isnt bad...
looks like ima need a transmission housing or a good welder....but hows my crankshaft???
Modified by HybridcivicLS-T at 11:04 PM 9/3/2008
Old 09-03-2008, 11:46 AM
elusivEm1's Avatar
Default Re: god DA-MN it! (Ricextacy)
that sucks..hope u get her back up..
Old 09-03-2008, 12:06 PM
PatrickGSR94's Avatar
crap dude, I have NEVER seen flywheel bolts sheared off like that. When was the last time you had the tranny/clutch off? Did you tighten the flywheel bolts and apply thread lock like you should have?
Old 09-03-2008, 01:05 PM
Ricextacy's Avatar
Default Re: (PatrickGSR94)
wow, that could of been the problem..i didnt own any power tools so we tighten it as hard as we could.
what is this Tread lock u speak of?
Modified by Ricextacy at 1:35 AM 9/9/2008
Old 09-03-2008, 01:44 PM
BoSox46GSr's Avatar
Default Re: (IntegraMark)
Thread Locker... meaning loctite, or some sort of adhesive to hold the bolts in place. They tend to loosen with constant vibration
Old 09-03-2008, 02:03 PM
Jet Life Til' The Next Life
Byaaah!'s Avatar
Default Re: (BoSox46GSr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">crap dude, I have NEVER seen flywheel bolts sheared off like that. </TD></TR></TABLE>
OP, how long from when you tightened them until that happened?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraMark &raquo;</TD></TR><TR><TD CLASS="quote">shame on you rebecca.</TD></TR></TABLE>
Hope it comes out good
Old 09-03-2008, 04:38 PM
Tarmac Junkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricextacy &raquo;</TD></TR><TR><TD CLASS="quote">
To get the broken bolts out, drill them and use an easy out. As far as your crank goes, If the threads are fine and you can get an accurate torqe on the bolts you should be ok.
Old 09-03-2008, 05:59 PM
be18see1's Avatar
holy jesus. that scares the crap out of me. i didnt use loctite on mine when i installed the new flywheel, although i did torque them to spec. good luck man!
Old 09-03-2008, 06:15 PM
SleepRdc2's Avatar
i say he over torqued them since he used a breaker bar and tightened it as much as he could.
Old 09-03-2008, 07:56 PM
crxstylin's Avatar
Default Re: (SleepRdc2)
wow, never seen that either, i have seen the heads of the bolts get messed up but not that way.
Old 09-03-2008, 09:31 PM
projectTeG's Avatar
from the looks of the flywheel and bolts i would call installer error.
overtorquing steel is one thing, but when you over torque(it looks aluminum). it will mushroom the metal and the the object will get play and move around and cause that.
i would say crank threads are damaged. normally if a bolt head breaks the remaining thread loose their stretch and can be threaded out by hand. Goodluck. i would start looking for a different bottom
just look on how many time people have overtorqued aluminum cam gears and cause damage.
Old 09-04-2008, 02:13 AM
Ricextacy's Avatar
Default da-mn!
it is an installation error. i had a couple guys help install my clutch (cuz ive never done it bfore)
they didnt: grease up the shaft, lube the bearing in the flywheel and didnt tighten down to specs...
it was running perfect for a good 2 months. i even took it down to Las Vegas and back to the Bay Area. and that day when i got back home..it happened.
Now. im on a hunt for money. my friend is selling me his GSR Built short block.
Is anybody looking for a 97 GSR short block with 130k on it. bolts are broken in the crankshaft but pistons and rods are great. PM me.
Old 09-04-2008, 07:24 AM
Topher.'s Avatar
Default Re: da-mn! (Ricextacy)
Is anybody looking for a 97 GSR short block with 130k on it. bolts are broken in the crankshaft but pistons and rods are great. PM me.</TD></TR></TABLE>
Hahaha...don't know why but that made me chuckle!
Thats a whole lot of errors. You live and you learn, next time get the proper torque specs and a tube of Loctite
Old 09-04-2008, 09:45 AM
projectTeG's Avatar
Default Re: da-mn! (Topher.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topher. &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a whole lot of errors. You live and you learn, next time get the proper torque specs and a tube of Loctite </TD></TR></TABLE>
&lt;&lt;&lt;doesnt use locktite, i just tq to spec and let it go. if you need locktite to hold the bolt then you need a new one. its tensile strength is gone.
Old 09-04-2008, 09:46 AM
Default Re: da-mn! (projectTeG)
I applied Loctite Red to all of my flywheel bolts and pressure plate bolts when installed my new clutch, just to be safe.
Old 09-04-2008, 11:27 AM
Hype-R Stalker
CleanLikeJdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;&lt;&lt;doesnt use locktite, i just tq to spec and let it go. if you need locktite to hold the bolt then you need a new one. its tensile strength is gone.</TD></TR></TABLE>
Sure, you can torque most things down without it, but some it says to use loctite.
What about factory bolts that come out all red and gunky?
Old 09-04-2008, 11:54 AM
projectTeG's Avatar
Default Re: da-mn! (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
What about factory bolts that come out all red and gunky? </TD></TR></TABLE>
mine didnt come out red and gunky.
no where in the helms does it say apply threadlocker.
Old 09-04-2008, 01:36 PM
Ricextacy's Avatar
damn how do pry off this flywheel!!
Old 09-04-2008, 03:04 PM
irev210's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">from the looks of the flywheel and bolts i would call installer error.
just look on how many time people have overtorqued aluminum cam gears and cause damage.</TD></TR></TABLE>
dont forget how important the torque sequence is as well.
No torque sequence, no torque wrench, epic fail.
Old 09-04-2008, 03:36 PM
aemintgsr's Avatar
x2
do the torque sequence and torque them to 76 ft lbs
Old 09-04-2008, 05:33 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">mine didnt come out red and gunky.
no where in the helms does it say apply threadlocker.</TD></TR></TABLE>
Agreed. I've probably done 50 clutch/flywheel jobs in miscellaneous Honda's and never have I seen mention of using any type of thread locker.
Not greasing the shaft and not lubing the bearing are relatively common oversights and tend to kill the pressure plate fingers and the input shaft, but overtightening is definitely the culprit here.
You have a very interesting and very correct bit of information above regarding overtorquing aluminum. I've seen pilot bearings seize and wobbles develop from overtorquing aluminum flywheels. I've never seen these issues arise from steel/chromoly ones.
Old 09-04-2008, 05:44 PM
C_Rock77's Avatar
Redundancy is your friend! An ounce of prevention is worth a pound of cure! Better safe than sorry!
Old 09-04-2008, 05:58 PM
Ricextacy's Avatar
Default Re: da-mn!
i had to learn the hard way, i hope everybody will learn from my mistake..
and tips on how to pull out this flywheel? it seems stuck but still spins.
Old 09-04-2008, 08:09 PM
projectTeG's Avatar
Default Re: da-mn! (C_Rock77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Rock77 &raquo;</TD></TR><TR><TD CLASS="quote">
Redundancy is your friend! An ounce of prevention is worth a pound of cure! Better safe than sorry!</TD></TR></TABLE>
well lets see here, does honda add threadlocker to their mass produced cars? no, so what should i change anything in that equation. honda did their research. plus if you understand how a bolt works as a spring.
Old 09-04-2008, 08:10 PM
projectTeG's Avatar
Default Re: da-mn! (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
You have a very interesting and very correct bit of information above regarding overtorquing aluminum. I've seen pilot bearings seize and wobbles develop from overtorquing aluminum flywheels. I've never seen these issues arise from steel/chromoly ones.</TD></TR></TABLE>
thanks i like to see that people share in the same experiences.
Quick Reply: Flywheel bolts......sheard
