ordered new rad...what coolant to get?
Old 04-14-2003, 05:59 AM
dip-set's Avatar
Default ordered new rad...what coolant to get?
ok so i noticed i have a pin hole in my radiator this morning...i get to work ..went to radiator.com...new oem replacement...126..shipped...now my question is...what antifreeze should i use if any other than honda/acura antifreeze and should i flush the system before putting in the new radiator...any tips on this whole precedure is appreciated...
thanks a mil....
Old 04-14-2003, 06:06 AM
ragejed's Avatar
Default Re: ordered new rad...what coolant to get? (teg-your-it)
honda coolant. flushing it would be nice.
Old 04-14-2003, 06:08 AM
dip-set's Avatar
Default Re: ordered new rad...what coolant to get? (ragejed)
any flushing advice...how many gallons of honda antifreeze do i buy?...
thanks...
Old 04-14-2003, 06:44 AM
26R
26R's Avatar
it's a new radiator, why do you need to flush?
Genuine Honda Coolant
Old 04-14-2003, 06:46 AM
dip-set's Avatar
Default Re: ordered new rad...what coolant to get? (SkunkdGS-R)
to flush out the block..or is that unnecessary..how many gallons of honda coolant is needed?
Old 04-14-2003, 06:49 AM
94ls's Avatar
i recently replaced my radiator w/ the same OEM replacement that you are referring to. Just an FYI, it works great. Since it's new, you wont need to flush the radiator, but make sure you dump the coolant from the engine block thoroughly and refill the radiator. It's approx 1.69 gallons (total) for a manual and 1.77 gallons if your teg is an automatic. Also I'd replace that thermo since you have a new rad and if you haven't done so already, sign up for http://www.team-integra.net That site has a lot of great info including "how to's" and basic maintance and DIY info. In my opinion, TI has better info regarding specific info for your teg but HT is a better discussion forum since TI unfortunately is slow. but good luck and pm me if you have any more questions..peace
Old 04-14-2003, 06:51 AM
94ls's Avatar
Default Re: ordered new rad...what coolant to get? (94ls)
also...honda coolant is suggested but prestone will work fine, just make sure you do the proper mixture!
Old 04-14-2003, 07:01 AM
VTEC-DA's Avatar
I have found that coolant doesnt matter at all. I have put so many different kinds in my car, and not one has kept the car cooler/hotter than another. I usually stick to Prestone though, sometimes Honda OEM fluid when I have it.
Old 04-14-2003, 07:05 AM
The Poopsmith's Avatar
Default Re: ordered new rad...what coolant to get? (VTEC-DA)
for those of you who ordered the OEM replacement radiator from radiator.com, did it have the nipple under the rad. cap for the overflow hose? I ordered one, and it came w/ no nipple, so if the radiator decides to let off a little fluid, its dumping all over my engine bay.
Old 04-14-2003, 07:06 AM
B-Tuning.com's Avatar
Honda Genuine coolant - in fact, they make a gallon container that is premixed 50/50 Water-Coolant. It'll run about 9 bucks at the dealer.
Old 04-14-2003, 07:15 AM
Rory Breaker's Avatar
Default Re: ordered new rad...what coolant to get? (B-Tuning.com)
According to Honda, only use Honda coolant due to the lack of boron & silicates...
but any green coolant will be fine. I use either Peak or Prestone...whatevers cheaper.
Old 04-14-2003, 07:43 AM
dip-set's Avatar
Default Re: ordered new rad...what coolant to get? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">According to Honda, only use Honda coolant due to the lack of boron & silicates...
but any green coolant will be fine. I use either Peak or Prestone...whatevers cheaper.</TD></TR></TABLE>
thank u moderator...
Old 04-14-2003, 08:31 AM
Aaron M's Avatar
if you get 2 bottles of the type 2 honda coolant(premixed), you'll have more than enough to fill up, and extra for top off's.
Old 04-14-2003, 08:43 AM
intekragsr's Avatar
Default Re: ordered new rad...what coolant to get? (SilverB18C1)
clean out your radiator first. Maybe its different from OEM, but when I got my new Fluidyne, all kinds of "man sauce" lookin stuff came out the top :X
Old 04-14-2003, 10:21 AM
disguy409's Avatar
Default Re: ordered new rad...what coolant to get? (DeeSeeToo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeSeeToo &raquo;</TD></TR><TR><TD CLASS="quote">for those of you who ordered the OEM replacement radiator from radiator.com, did it have the nipple under the rad. cap for the overflow hose? I ordered one, and it came w/ no nipple, so if the radiator decides to let off a little fluid, its dumping all over my engine bay.</TD></TR></TABLE>
Mine came with it...I ordered from radiator.com
Old 04-16-2003, 05:15 AM
dip-set's Avatar
update...radiator is in...install was a breeze...less than a hour...thanks to you all for the tips and advice....
Old 04-16-2003, 05:18 AM
Evilteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkdGS-R &raquo;</TD></TR><TR><TD CLASS="quote">it's a new radiator, why do you need to flush?
just bc the rad is clean doesnt mean that its fully out of the engine and heater
Old 04-16-2003, 05:43 AM
MachAF's Avatar
Default Re: ordered new rad...what coolant to get? (Evilteg)
AS rageJD said. Definently flush the system.
kadavis90
09-08-2017 11:40 AM
scspeed
07-24-2008 01:48 PM
Dc_John
02-02-2008 04:28 PM
Paprika
13
12-27-2006 08:43 AM
korean_teg
10-25-2004 11:39 PM
Quick Reply: ordered new rad...what coolant to get?
