Uh oh...
Old 10-30-2006, 05:44 PM
aaronISthrowed's Avatar
Default Uh oh...
Driving my car today with a friend and it was making all kinds of knocking noise. I just got my turbo tuned a few days ago and ive drove it pretty hard a few times. Well we couldnt figure out was was making the noise. Thought that it was the finder hanging down or a broken boot.
Turned out that 3 out of 4 of my lug nuts were loose I could of taken them off with my hand.
This is just a reminder to check you luggss.
Old 10-30-2006, 06:02 PM
mtpktz.'s Avatar
Default Re: Uh oh... (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Driving my car today with a friend and it was making all kinds of knocking noise. I just got my turbo tuned a few days ago and ive drove it pretty hard a few times. Well we couldnt figure out was was making the noise. Thought that it was the finder hanging down or a broken boot.
This is just a reminder to check you luggss.</TD></TR></TABLE>
Lucky you.
Man, I hear this knocking noise on the front left side of the car... sounds like its coming from the wheels. It only makes the noise when I press the brakes. It's a 99 GSR with steelies on it and DUMPED. I just bought the car so I'm not really familiar with what it could be. Any ideas?
Old 10-30-2006, 08:38 PM
Default Re: Uh oh... (mtpktz.)
Could be a loose finder or weak motor mount or something. I don't know, its hard to say without hearing the noise.
Old 10-30-2006, 09:10 PM
Spoon ITR's Avatar
Motor mount sounds possible to me
Old 10-30-2006, 09:13 PM
mtpktz.'s Avatar
Default Re: Uh oh... (jdmdc2gsr)
hmm. Thanks for the input guys. Changing motor mounts sure is a PITA
Old 10-30-2006, 09:19 PM
mtpktz.'s Avatar
I'm curious though, how expensive are they to change out?
Old 10-30-2006, 09:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. &raquo;</TD></TR><TR><TD CLASS="quote">I'm curious though, how expensive are they to change out?</TD></TR></TABLE>
I dunno but i need to change mine too.
Old 10-30-2006, 09:26 PM
mtpktz.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">I dunno but i need to change mine too. </TD></TR></TABLE>
Do you generally change them all at the same time?
I was searching Ebay, and found all 5 GSR mounts for 199 shipped
Old 10-31-2006, 04:57 AM
Racermech's Avatar
What is a finder???? Ohhh you mean fender......
The lower motor mounts are actaully pretty easy to change. The upper rear is the real pain. If you mounts are not rippes them you could get a prothane or energy suspension morot mount kits.
As far as your knocking, I am will to be it is your axles. It is pretty common when you car is slammed. It just puts a lot of extra stress on the axle. Truck guys have the same issue when they are rasied too much.
Old 10-31-2006, 06:31 AM
mtpktz.'s Avatar
Default Re: Uh oh... (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">What is a finder???? Ohhh you mean fender......
As far as your knocking, I am will to be it is your axles. It is pretty common when you car is slammed. It just puts a lot of extra stress on the axle. Truck guys have the same issue when they are rasied too much.</TD></TR></TABLE>
Hmm. I need to raise the car up anyhow so I can get on the rollers to do emissions because they said I was too low. So I guess I'll find out then.
It's weird though because it only happens when I brake, and ONLY when I brake.
Old 10-31-2006, 07:09 AM
I dont know if i would trust motor mounts off ebay.
Old 10-31-2006, 07:24 AM
mtpktz.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if i would trust motor mounts off ebay.</TD></TR></TABLE>
I was thinking the same.
I'll probably just go aftermarket.
Old 10-31-2006, 07:46 AM
BryaninVegas's Avatar
Lucky you.
Man, I hear this knocking noise on the front left side of the car... sounds like its coming from the wheels. It only makes the noise when I press the brakes. It's a 99 GSR with steelies on it and DUMPED. I just bought the car so I'm not really familiar with what it could be. Any ideas?</TD></TR></TABLE>
Damn... that's most likely your brake calipers and rotors. After awhile when the calipers wear out they pulsate when you stop, which causes warped rotors. That's where your getting that knocking noise when stopping. Does the steering wheel shake really bad when you stop too?
My old Eclipse did that so bad lol I mean it wouldn't stop after a bit on the brakes lol.
Bottom line, get them checked. If I am right, you need the calipers, rotors and pads. If you can put them on yourself, it shouldn't be too hard.
Old 10-31-2006, 07:54 AM
mtpktz.'s Avatar
Default Re: Uh oh... (BryaninVegas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryaninVegas &raquo;</TD></TR><TR><TD CLASS="quote">Damn... that's most likely your brake calipers and rotors. After awhile when the calipers wear out they pulsate when you stop, which causes warped rotors. That's where your getting that knocking noise when stopping. Does the steering wheel shake really bad when you stop too?
Bottom line, get them checked. If I am right, you need the calipers, rotors and pads. If you can put them on yourself, it shouldn't be too hard.</TD></TR></TABLE>
The steering wheel doesn't shake at all. When it first started happening that is what I thought as well, but now that somebody mentioned motor mounts, I think thats where the problem lies. We shall see.
Thanks for the response.
Old 10-31-2006, 07:56 AM
Does the shake at Idle?
I always remember that when the motormount is going bad, the motor will shake at idle.... correct me if I'm wrong please.
Old 10-31-2006, 07:58 AM
mtpktz.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryaninVegas &raquo;</TD></TR><TR><TD CLASS="quote">Does the shake at Idle?
I always remember that when the motormount is going bad, the motor will shake at idle.... correct me if I'm wrong please.</TD></TR></TABLE>
Interesting you mention this... If I start the car for the first time in the morning, it shakes a bit and the RPM's fall, but it only happens once. Because if I shut the car down, and start it back up, it stays at a steady 1k Idle.
Old 10-31-2006, 02:08 PM
I'll probably just go aftermarket.</TD></TR></TABLE>
Or you could just stick to OEM, i might just do that.
Old 10-31-2006, 02:13 PM
mtpktz.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Or you could just stick to OEM, i might just do that.</TD></TR></TABLE>
Surprisingly, OEM is more expensive than aftermarket, hence why I'm going to aftermarket.
Old 10-31-2006, 02:20 PM
cm zak's Avatar
Same **** happened to me, knocked around and tore part of my rim's lug spots up, but i jsut put new studs in and fixed it all up, (They had broken off )
Old 10-31-2006, 03:30 PM
Semper Fidelis
SlammedDC2's Avatar
Default Re: (cm zak)
I was having a similar problem with a noise like that when applying the brakes. Took them off to change and found they were warped and almost no meat left on them at all.
Old 10-31-2006, 03:32 PM
mtpktz.'s Avatar
Default Re: (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I was having a similar problem with a noise like that when applying the brakes. Took them off to change and found they were warped and almost no meat left on them at all.</TD></TR></TABLE>
Thanks. Gonna have to check that soon.
skater5067
23
04-04-2023 09:19 AM
tealchief
15
03-17-2010 07:40 AM
Turbo_y8
05-07-2006 02:47 PM
TheNasty0ne
11
11-29-2005 04:58 PM
b8er
10-29-2004 02:48 PM
Quick Reply: Uh oh...
