Turn Signal Wiring Woes
Old 10-29-2004, 10:53 AM
Kellindal's Avatar
Default Turn Signal Wiring Woes
So I bought the sockets and what not to replace what the thieves cut off on the driver side after stealing my clear corners...
I went to put it all together... there are two extra wires near the main turn signal bulb, so I'm not sure which 3 wires to connect. There are 2 red, 2 black and 1 green. I connected 1 of each color to the main socket. So then I tested it.
With headlights off: turn signal right (passenger, which wasn't cut) works fine, turn signal left (driver, which was cut) works fine.
Headlights on: There are two bulbs behind the turn signal. I think the smaller one is supposed to be on when you turn the headlights on. Passenger side, second light comes on. Driver side, main bulb comes on. Also, with headlights on, my left (driver side) turn signal on my dash display comes on. This makes sense to me because I think the wrong light is turning on with the headlights on. Also, turn signal left (driver side) blinks differently and makes different noises inside the car with the headlights on. This also kind of makes sense because of the wrong light thing again.
I'm going to try the other two wires, but I don't see how that will change the secondary light wiring, unless connecting the wrong two wires some how shorts out the secondary bulb. Anybody have any insight into this wiring. I'm going to try changing the wires first chance i get, but i'm wondering what people think.
Old 10-29-2004, 06:42 PM
Kellindal's Avatar
Default Re: Turn Signal Wiring Woes (Kellindal)
bump
Old 11-04-2004, 08:31 PM
Kellindal's Avatar
answers anyone?
Old 11-04-2004, 08:33 PM
2NR0066's Avatar
same problem here , mine were cut off and i need to figure out how to rewire them , both mine were ripped off and the driverside seems to have more wires
Old 11-06-2004, 01:00 PM
Kellindal's Avatar
Default Re: (2NR0066)
So answer this first.... on 98+ integras, with the headlights on, which bulbs on the turn signals are on? The main bulb or the smaller bulb on the side?
Old 11-06-2004, 01:44 PM
SmurfDA's Avatar
Location: I live in a town with Boston traffic, mass, united states
Default Re: (Kellindal)
get a helms manual, or a haynes manual, they have wiring diagrams
Old 11-07-2004, 09:48 PM
Kellindal's Avatar
Default Re: (93TealSi)
simple question asked.... someone just go turn on their lights and check for me?
Old 11-08-2004, 10:58 AM
Kellindal's Avatar
this should be a simple one.... anybody?
kr0n1c
04-15-2011 03:34 PM
landon.alder
11-20-2009 08:02 AM
propwdialogue
01-21-2008 12:15 PM
gfunkmos37
01-26-2005 09:35 AM
Quick Reply: Turn Signal Wiring Woes
