torque specs for b18c1 valve cover
Old 06-26-2009, 10:08 PM
Rtboy10's Avatar
Default torque specs for b18c1 valve cover
Hey guys just wondering what the torque specs for the valve cover nuts are thanks.
Old 06-26-2009, 10:40 PM
ek-g6's Avatar
Default Re: torque specs for b18c1 valve cover
I believe it's 8ft/lbs.
Old 08-29-2010, 11:52 AM
civicqueen92's Avatar
I need to know the torque specs for a B18C1 with ARP head bolts... Can any one help me?
Old 08-29-2010, 12:10 PM
komat's Avatar
hand tight is good enough for the valve cover.
dont use a tq wrench....
Old 08-29-2010, 08:58 PM
keepinitrehaal's Avatar
Twist them down by hand and about a 3/4 turn should do the trick.
Old 08-29-2010, 09:03 PM
mouab18c1's Avatar
If you have the box the studs came in then it should be on it if I remember right or it should be on a piece of paper on the inside.
Old 08-29-2010, 09:24 PM
Tighten the nuts to 80 ft. lbs IN THREE EQUAL STEPS. Example, torque to 25 ft lbs, then, 50 ft lbs, then 80 ft lbs.
Old 08-29-2010, 09:25 PM
Oh, and dont forget to use the Faster lube provided in the kit.
twkdCD595
10-22-2021 02:10 PM
my93hatch
02-16-2005 04:19 PM
capcon83
03-31-2002 03:38 PM
memphiss13
12-12-2001 08:21 AM
1fastGSR
10-01-2001 04:20 PM
Quick Reply: torque specs for b18c1 valve cover
