step by step fitting ITR recaros to jdm DA6 91 integra
Old 09-30-2009, 03:53 PM
hogster's Avatar
Icon7 step by step fitting ITR recaros to jdm DA6 91 integra
first time doing a write up so here it goes
took a few hours but well worth it and big big thanks to my uncle rob the brains behind it
so:
-i had a spare set of standard da teg seats which i took off the rails only a few bolts holding them together.
-we measured the recaro seat bolts there are 3 each side of the seat and from bolt centre to centre the distance is 16inches apart.
-now the front holes on the teg chassis is exactly 16'' but the rear holes are 17.5'' thus the rails need modifying.
-one side on the rail is flat on top but the other side has 2 brackets attached with rivets so we drilled through these rivets about 4 in total and with the help of a hammer the came off pretty easy.
-next thing is to swap the front 'L' offset'd shaped bracket that attaches to the rail with the rear straighter 'L' shaped braket.
-this will allow the front hole to stay at 16'' and the rear offset one will move the rail inwards reducing the 17.5'' gap closer to 16''.
-those bracket are held on with a rivet each and a weld that can be seen so drill through it they will pop off hel from hammer again ha.
-do the exact same of the other side reverse the front and rear brackets and that the rail tops are flat.
-we got some nuts and bolts think about 10mm il check exact 2moro that were toughen'd steel to attach the brackets back on.
-one hole matches from rivet that was drilled put bolt in tighten that and then drill the other and bolt it up so theres 2 bolts holding the 'L' brackets at each end do the and same on other rail.
-we then bolted both rails down 4 bolts in total and made sure from centre to centre on each rail was 16'' which it was may need to be tapped with hammer.
-using the hole that is from factory bolt on one side on the rail we measured back 260mm centre to centre and that was where we drilled another hole for the rear recaro bolt and from the front one came back think 25mm for the 2nd bolt,3 altogether on each rail.
-copy the measurement exactly to the other rail.
-now take the rails back off and if measurements are correct and centred the will bolt right upto the recaro seat holes 6 in total.
-then just bolt the seats back in and bingo your done and do it all over again on the other side.
-once we figured out what to do it was preety easy mainly just had good 1/4 steel drill bits chisel and lump hammer and double check measurements.
-heres some pics any questions just ask all cost was my uncles time and few nuts and bolts.
Old 09-30-2009, 04:01 PM
hogster's Avatar
Default Re: step by step fitting ITR recaros to jdm DA6 91 integra
i also fitted an ITR momo wheel and gear ***
have 16'' drag dr20's in gold arriving next week to ireland
already put a need eg b16a2 into it as original big ends went
fitting a j's racing induction kit and relocating the battery to boot 2moro
and putting standard exhaust on to with manifold and decat
after that its bc racing coilovers and a respray
opinions
Old 09-30-2009, 07:53 PM
Jpad626's Avatar
alright i put some racing seats in to my 92 integra gs and wen i swaped seats from the stock leather to cloth seat i got frim a civic i had to take the seat belt harnes of my old seat to get rid of a beeping and to kill the seat belt light comming from the dash. now i put 2 racing seats in there and i have no idea where to look to get rid of the constant beeping. any chance you can help me out.
Old 09-30-2009, 08:09 PM
solehead714's Avatar
There's a seatbelt brain on the passeners side, take out the kick panel and there's 2 plugs goin into it. Unplug them and take out the screw for on the bracket for the brain and ur all set!
Old 10-01-2009, 06:24 AM
Jpad626's Avatar
alright im gonna have to try that thanks you man
Junaid K
09-04-2014 11:09 PM
John F
02-17-2005 06:30 PM
HybridGSR1
07-25-2003 10:18 PM
JICsube
11
12-31-2002 01:14 PM
DIY_Racing
09-19-2002 08:59 AM
Quick Reply: step by step fitting ITR recaros to jdm DA6 91 integra
