squeaking sound when shifting?
ok i drive a 00 integra ls with roughly 22k miles. During normal driving, shifting 2nd to 3rd there is an annoying squeak right after the clutch is engaged. the high pitched squeak sounds like its coming from rear possibly?or maybe the engine somewhere? can someone help me out this is really annoying me
Re: squeaking sound when shifting? (00b18b)
Poke your heatshields with a broom, if they squeek, thats your culprit. I had the same prob, and went to a tp and it was gone.
gmoore
gmoore
I used to get an annoying squeaking/clicking noise from my clutch pedal under engaugment, and slightly under disengaugment... I looked under there and found the culprit to be a bad spring located just behind the clutch pedal... I lubed it with WD40 and it went away for a while, but comes back every now and then... HTH...
Re: squeaking sound when shifting? (tegunderpressure)
Do what tegunderpressure says, if it doesn't work, lube your slave cylinder, if that doesn't work, it's most likely your throwout bearing. Ouch! I had the same problem, but the dealer was nice enough to replace it under warranty.
IsitCosIisBlack
06-16-2006 09:49 AM
