Speedometer Died and Bogging=no Vtec
Old 10-06-2002, 03:00 PM
NationsMostWanted's Avatar
Default Speedometer Died and Bogging=no Vtec
i just got my new clutch installed and now my speedometer isnt working. i also noticed its bogging too when the vtec is suppose to kick in. but since my speedometer is dead the vtec isnt working no more. i found the sensor on the transmission where the speed sensor is plug it and thats fine...wheres the other end of that sensor located at?any advice?
Old 10-06-2002, 04:02 PM
TEGME's Avatar
Default Re: Speedometer Died and Bogging=no Vtec (2000civicgsr)
there is a cable comming off of your throttle body, look at your tranny on the top and there is a little connection, at the end of this cable is a gray plug, plug this gray plug into the plug-in on top of the tranny and you will be good to go, just look around for a set of wires that arent plugged in, let me know if this works, they usually disconnect this when they do tranny/clutch work and it is easy to forget to plug it back in.
Old 10-07-2002, 10:14 AM
Default Re: Speedometer Died and Bogging=no Vtec (TEGME)
ok i got it fixed. the sensor that plugs to the tranny has 3 wires on the sensor. found out one of the wires were ripped off and push in so i fixed it and the bogging was frommy throttle body sensor was on backwards...seems dangerous cuz my sensor broke to it was connected with half the sensor to the plugs on the throttle body. i flipped it back around and everythings good.
B16CRXVTEC
22
10-04-2011 06:27 PM
damn_import_culture
Transmission & Drivetrain
07-20-2009 07:27 PM
thesilverfox
11-01-2007 06:49 PM
ptnguyen
02-14-2007 07:29 PM
Quick Reply: Speedometer Died and Bogging=no Vtec
