slave cylinder or hose is bad?
Put a new CMC in, car drove fine for day. On the way home, car wouldnt go into gears. CMC not leaking checked. No leaks on the lines the metal ones that go to the slave and cmc. But i see fluid on the bottom of the reservior fluid to cmc hose, the bottom part of the hose that goes on the cmc. Is it that or did mt slave go bad??
1 Post
Re: slave cylinder or hose is bad?
How much fluid did you notice at the hose junction? How did you conclude you have no leak if you found fluid outside of the reservoir?
Bleed the clutch lines real good, make sure there's no air, and see if that helps your situation.
Around the hose. It is a ok amount. If you put your finger on it, it will be wet with fluid. I think that is enough to cause air into the system??
niceprelude
06-02-2011 02:50 PM
