side markers
side markers
wassup guys, i just installed side markers on my car, and connected the lines to it, but how do you make it so when you turn on the light, the sidemarkers light up too? the sidemarkers only light up when I click on the turn signals. thanx in advance
that's actually the way they 'should be' -- check the achives though. I believe someone posted a wiring diagram for them (seems like you could just pull from your headlights though).
for the record, I prefer mine on when the light are on and blinking w/ the signals as well. Me = HT rice.
Re: (ihaveamustang)
u wire them to the running light, and then they blink opposite of ur actuall blinker cuz the running light goes off wen the blinker lights up. at least thats how it was on my accord back in the day... idk for sure about integs but i hope this helps in some way...
Re: (LSintegra)
hook it up the the bumper light, the big bulb has 3 wires, one is a ground, one is a constant, one is a flasher. I believe the balck is ground,red is constant and green is flasher. You have it hooked up to the ground and the flasher, you need to hook it up to the constant and the ground.
Do a search on the wirs colors, i could be worng, been a while since i hooked mine up.
upstate
07-21-2004 12:46 PM
