removing ABS light with a different ECU? Passing inspection issue.
Old 06-26-2007, 11:16 AM
pearl's Avatar
Default removing ABS light with a different ECU? Passing inspection issue.
I have a 01 Integra. The inspection is up and I have no issues with passing, except the ABS light. I really do not care for using it.
Is there a way I can use a different ECU (p28 w/o abs) to pass inspection and to remove the abs light?
Can I pass NJ State inspection with the abs light on?
Thanks for your help
Old 06-26-2007, 11:30 AM
pearl's Avatar
Default Re: removing ABS light with a different ECU? Passing inspection issue. (pearl)
I've been told just to remove the bulb, I assume that the inspection for ABS is just visual? everything else works fine.
Old 06-26-2007, 11:47 AM
* B A N N E D *
St Jimmy's Avatar
yes, just remove the bulb.
Old 06-26-2007, 11:49 AM
pearl's Avatar
Default Re: removing ABS light with a different ECU? Passing inspection issue. (St Jimmy)
so its just visual? awesome. that saves a load of time. anyone from jersey have any experience with this?
Old 06-26-2007, 02:30 PM
DOHCgarage919's Avatar
Location: Why To Steal My Car, NC, United States Of America
i live in nc and i passed inspection i had abs light on and airbag light on and passed with flying colors
Old 06-26-2007, 02:48 PM
pearl's Avatar
Default Re: (DOHCgarage919)
looks like ill give it a shot friday
Old 06-26-2007, 03:38 PM
Daisy... Daisy...
Dogginator's Avatar
The ECU does not affect the ABS light. Why don't you pull the ABS code the same way that you would the ECU codes (jumper the connector in the passenger kick panel and read the ABS light) and see what the problem is? Otherwise, pull the bulb or the ABS fuse in the underhood fuse box by the ABS unit.
Old 06-26-2007, 05:14 PM
pearl's Avatar
Default Re: removing ABS light with a different ECU? Passing inspection issue. (Dogginator)
i know what the code is, and i have no problem fixing it. the inspection was due 4/07, so i'm really just trying to not get popped for a ticket.
Old 06-26-2007, 06:14 PM
Blahblah718293's Avatar
id pull the bulb not the fuse, they may see the fuse missing and say somthing. id just pull the bulb. or you could just fix the problem and you wont have to worry about it.
Old 06-26-2007, 06:16 PM
pearl's Avatar
Default Re: removing ABS light with a different ECU? Passing inspection issue. (Blahblah718293)
i pulled the 10A fuse on the abs module and started the car and the light was still on. i didnt try and reset the ecu though. oops
looks like ill try the bulb and reseting the battery too.
Old 03-24-2008, 07:53 AM
pearl's Avatar
I put this off until now, and i need it done. can anyone in New Jersey verify that pulling the bulb WILL pass?
DC206R
10-18-2009 09:26 AM
DC231_01
06-26-2006 08:37 PM
Shaun92lude
12-08-2004 07:11 AM
Quick Reply: removing ABS light with a different ECU? Passing inspection issue.
