rear main seal torque specs
Old 08-03-2004, 02:12 AM
tegasaurus's Avatar
Default rear main seal torque specs
just wondering what the rear main seal torque specs are... in my haynes manual it says 96 ft-lbs but that seems pretty high for those little 10mm bolts - i might also be reading the specs for something else and am unaware.
tia!
Old 08-03-2004, 04:17 AM
3.504's Avatar
Default Re: rear main seal torque specs (tegasaurus)
i found that # 1 and 5 main cap's have 56lb/ft (11mm bolt)
the seal cover plate is 8 lb/ft (6mm bolt)
and the seals themselves are drive in, so they dont have a torque spec.
these are the honda specs. i dont know what else you'd be looking for, but please give some better info on what you are. also, please put up the year/car/motor in tech posts.
Old 08-03-2004, 10:58 AM
tegasaurus's Avatar
Default Re: rear main seal torque specs (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">i found that # 1 and 5 main cap's have 56lb/ft (11mm bolt)
these are the honda specs. i dont know what else you'd be looking for, but please give some better info on what you are. also, please put up the year/car/motor in tech posts.</TD></TR></TABLE>
i already know the main cap specs... and those you provided are for the GSR/itr (56 outside and 49 in 1/2/3 i think). oh well... i just secured the bolts on their firmly with the smallest ratchet i had... so im guessing 10-15 ft/lbs
Old 08-03-2004, 08:04 PM
3.504's Avatar
those specs were takin from a 95 LS
Old 08-04-2004, 05:10 AM
m R g S r's Avatar
With some hondabond, that should be fine. you realy don't need to torque those tiny bolts with the 10mm head.
jimmyjun0213
Acura TSX
06-14-2015 09:15 AM
ray.riddler92
07-27-2011 05:07 PM
onwisconsin81
04-05-2010 01:25 AM
rasinhell
01-24-2005 07:39 AM
2000Accord5sp
12-10-2002 07:40 AM
Quick Reply: rear main seal torque specs
