Power steering cooler, is it necessary?
Old 08-31-2010, 09:32 AM
all-mtr-teg's Avatar
Default Power steering cooler, is it necessary?
Is the power steering cooler necessary, the one that mounts in front of the a/c condensor onto the radiator support? I'm trying to tuck my a/c and p/s steering hoses and lines, and was thinking of bypassing the p/s cooler.
Old 08-31-2010, 12:02 PM
Drive 4 fun's Avatar
Default Re: Power steering cooler, is it necessary?
As I recall, LS does not have, GSR has a loop, and Type R has a loop with some cooling fins. I think that part of the problem is that at higher rpms, the pumping generates heat. You could drive the system less, different pulley size, or try without. Not necesssarily a good idea if you track or hold at higher rpm.
Old 08-31-2010, 12:20 PM
ruffrhyder's Avatar
I don't really see how the GSR "cooler" would even be effective. Like you said, it's basically a U shaped pipe mounted in front of the a/c condenser. There aren't any fins or large surface area to help dissipate heat.
Old 08-31-2010, 01:24 PM
A loop of aluminum tubing with full air flow could dissapate just enough heat to keep things below cooking temp. I was told that on a track, that the PS pump bearing and seal, and hose crimp, metal to rubber, take a beating on the LS and that the cooler is enough to help that. I guess some engineer put it there for a reason, the number crunchers would have stopped otherwise.
Old 08-31-2010, 01:29 PM
Spawne32's Avatar
If you really must go without it, i would run a good full synthetic PS fluid with a high boiling point instead.
Old 08-31-2010, 02:58 PM
SleeperGSR's Avatar
I think it depends on how you drive the car. For the roads and daily driving, i don't think you need P/s cooling. however, if it was designed into the car it must be there for a reason. So i would keep it unless its broken or you are removing the p/s compleatly. I go to hpde's alot and have noticed that the p/s resivor gets extreamly hot after a 30 min session. If i ever were to boil the fluid i would add some cooling, but i haven't yet. I will be switching fluids to a more high temp. is there an easy way to flush/bleed the power steering system???
Old 08-31-2010, 03:04 PM
Again, I have heard of problems with the PS hose cooking at the metal rubber interface, that could happen before boiling. I would use the cooler unless for casual DD. RPM's to the pump seem to cause the temperature, and of course nobody revs, right??
Old 08-31-2010, 03:18 PM
4stagecandy's Avatar
i removed mine when i changed all my power steering lines to an fittings and hoses no problems as of 10,000 miles
Old 08-31-2010, 05:07 PM
Where do you live? How hot do your summers get? Here in cali, 115 oF in summer isn't uncommon.
Old 08-31-2010, 05:20 PM
i live in cali in riverside
ZOMBIEKILLER
03-01-2008 03:05 PM
ericstambaugh07
04-21-2007 03:01 AM
AccordRacing
06-08-2005 05:04 AM
VTECAcuraGSR
04-11-2005 04:42 AM
smkngsr
03-20-2003 10:32 PM
Quick Reply: Power steering cooler, is it necessary?
