Over Revving Damage?
Old 10-06-2001, 02:55 AM
Rhetoric's Avatar
Default Over Revving Damage?
I was at around 90mph on 5th gear and was going to downshift to 4th accidently went to second and saw my tach hit off of 10k. After I heard the loudest ticking noise I've ever heard coming from the head/block area. Lost acceleration as the rpms climbed. Eventually my oil was gone (I just changed it last week too) and my motor started to overheat. I pulled over to inspect to only hear it ticking or (some kind of metallic hitting) bang even louder. Im pretty sure I need a new longblock now , but anyway what may be some diagnosis you guys can give me. Im pretty bummed on it, I've seen horror stories in the past with the valve going straight into the piston. My setup was 01 itr cams, portflow springs, itr outter springs,crower retainers and p28 skunk no rev limit.
Old 10-06-2001, 04:58 AM
non-VTEC's Avatar
Default Re: Over Revving Damage? (G S R)
wow............maybe spun a rod bearing? or valve to pistion contact?
even with the upgraded valve train you have i dont know if there safe up to 10000rpm?
i think it might be a rod bearing.........i've heard really loud ticking that sounded like it was coming from the head area but it was infact a spun rod bearing.......
hope you have good luck on your re-build!
Old 10-06-2001, 06:28 AM
New User
slowerthanu's Avatar
This is why I always like to have the rev limiter there, although in this situation, I dont think the ECU would have been able to react fast enough. 10000 rpm probably did a Job on the bottom end, But I cant be sure, I say take i apart and rebuild, if not, ITR bottom end time
Old 10-06-2001, 09:05 AM
Luke's Avatar
Default Re: Over Revving Damage? (slowerthanu)
Whats the best rev limiter out there?
Old 10-06-2001, 10:53 AM
OneThirtyEight's Avatar
Default Re: Over Revving Damage? (luke)
a fast foot on the clutch. No electronic rev limiter can stop the parts from moving, inerta is greater than the rev limiter.
Old 10-06-2001, 10:55 AM
New User
Default Re: Over Revving Damage? (97blackteg)
I prefer a soft touch to a factory rev limiter, and yes I have been stopped by the rev limiter a few times, but it will not stop you on a 5th to 2nd downshift like that. You infact need quick reflexs in those situations.
Old 10-06-2001, 01:11 PM
Rhetoric's Avatar
Default Re: Over Revving Damage? (non-VTEC)
I just got it towed home. Noticed the timing belt is loose now and about to slip off. Also my the alternator drive belt was flipped upside down and apparently about to break. The noise is coming from the block, sounds like it is about to bust through the header or something. Im hoping that my head is okay though. This repair is going to be expensive. I'll post pics of the damage when I can get everything opened up.
Old 10-06-2001, 02:03 PM
Evil DOHC's Avatar
U would be lucky just to get away with bent valves. But the pistons could of touched the valves and damaged the piston itself. Good Luck
EVIL
Old 10-06-2001, 03:55 PM
X2BOARD's Avatar
Default Re: Over Revving Damage? (Evil GS-R)
How'd you manage to get the shifter into 2nd at 90 ?
Old 10-06-2001, 04:08 PM
New User
thefungus's Avatar
Default Re: Over Revving Damage? (X2BOARD)
this seems like an all-too-common
problem lately and i'm wondering
what circumstances you were in
when this happened.
EM2004
Transmission & Drivetrain
09-22-2011 07:41 AM
Flip's DC5
22
03-28-2008 08:33 PM
Cheeech
24
01-04-2006 06:07 AM
kezzy4
03-16-2005 12:03 AM
JMod
08-22-2003 01:43 AM
Quick Reply: Over Revving Damage?
