One problem after installing ITR rear swaybar.
New User
I had a slight problem after installing the ITR rear swaybar on my car.
The ITR rear swaybar was installed perfectly with the BSQ kit but with the ITR rear swaybar installed, my Neuspeed lower tie bar doesnt fit.
Does anyone know of a lower tie bar that will fit with the ITR sway bar?
Pictures would help too.
Thanks
Thanks
Re: One problem after installing ITR rear swaybar. (BlueG3Teg)
If you search for "ITR sway bar" you'll get a few posts, and in one of them there's a thread where there are some pics of a few tie bars that fit.
The following will fit with the ITR sway bar: Spoon, Benen, Comptech.
*Comptech requires drilling on the lower arm(?) eight holes to be exact.
I think DC will fit, but nobody should use that POS anyway.
Re: One problem after installing ITR rear swaybar. (Pb_Foot)
For the Comptech, you drill 8 holes, but in the subframe, not the LCAs. It mounts exactly like the ITR tie bar. See my web page for pics. This tie bar will fit with a big rear sway bar.
Re: One problem after installing ITR rear swaybar. (Stephen)
ah...yes its the subframe!
Anyways, I decided to go with Benen because they directly bolt on, are cheaper than comptech, and most likely of equal quality if not better than the comptech.
Only reason I wanted comptech was because it came in red.
Re: One problem after installing ITR rear swaybar. (Calavera)
http://www.geocities.com/beaksproducts/upgrade.html
This should help you out.........
B18C1_EK
02-28-2002 12:01 PM
