Ok to use White lithium grease on rubber?
Old 10-27-2002, 06:32 AM
ragejed's Avatar
Default Ok to use White lithium grease on rubber?
I read someone online (H-T) that its bad to use White lithium grease on polyurathane mount iserts becase it slowly eats at the polyurathane. I need to replace all the crap on the bottom of my shifter, and there are rubber o-rings on it...Will it be a good idea to use white lithium grease on them? Its the only grease i have. Thanks
Old 10-27-2002, 06:43 AM
StyleTEG's Avatar
Default Re: Ok to use White lithium grease on rubber? (ragejed)
Alot of people recommend a siliconed based lubricant for poly bushings.
I beleave 3 in 1 is silicone based.
Old 10-27-2002, 06:59 AM
ragejed's Avatar
Default Re: Ok to use White lithium grease on rubber? (StyleTEG)
Alright, but im not lubing poly...I am going to lube normal everday rubber o-rings..
Old 10-27-2002, 07:41 AM
ragejed's Avatar
so..
Old 10-27-2002, 08:45 AM
ingrate's Avatar
i put white lithium on the poly bushings that came with my progress camber kit.. been like that for well over a year and so far no problems..
Old 10-27-2002, 09:52 AM
ragejed's Avatar
Default Re: Ok to use White lithium grease on rubber? (In7egrity)
Alright, I picked up some silocne based disc brake grease..its like damn paste, lol
fryman
09-24-2011 08:39 AM
soloIntegra
05-12-2003 12:32 PM
Quick Reply: Ok to use White lithium grease on rubber?
