Oil you guys use?
Re: Oil you guys use? (*****GotRice)
I started off using Castrol GTX 5w30, then switched to Mobil1 5w30 at 85k miles, and soon (as in next oil change) I'll be switching to Amsoil 10w30.
Re: Oil you guys use? (Integraholic)
0w30? man that must be like water. I'm on Mobil 1 synth. 5w30 right now, but I will probably switch to 10w30 this weekend. In the future I may end up just going w/ Valvoline Max Life.
Re: Oil you guys use? (brwnrice)
Well, all of my friends and I run 0w 30 because it is thin. When you start it up, it pumps easily and give you instant oil pressure. Also, oil is resistance to the crank trying to turn. So least resistance is more HP. Well, my theory anyway.
I ran (in order):
5W-30 Valvoline
5W-30 Pennzoil Synthetic Blend
5W-30 Mobil1
5W-30 Valvoline Max Life
I've been using Max life for the past 15k+ miles. Supposedly, the formula conditions seals to slow down wear and tear. Mobil1 was nice, but I could not keep up with the costs.
Here's an informative thread on oil: https://honda-tech.com/zerothread?id=163845
5W-30 Valvoline
5W-30 Mobil1
Re: Oil you guys use? (PatrickGSR94)
I'm running with Amsoil 0 w30
Havent lost or burnt off any oil for over 4k so far. suppost to be good for at least 30,000 miles or one year. I dont think I can wait that long tho to change it. my thoughts are the washer might go bad. so I should change it anyways.
For $8-$10 a quart it better be good.
I have 128k on a 93 Integra LS, I run Mobil 1 Full-Syn 10w30
For some reason olive oil didn't work to well, I thought at least I could lower my cars cholesterol level.....
