oil filter wrench size
Old 04-06-2003, 07:57 PM
envious1320's Avatar
Default oil filter wrench size
I need to know what size oil filter wrench to get to remove the filter from my 96 gsr. I want the round wrench that goes on the end of a wrench or socket wrench and fits right over the filter. Not the clinch one. they go by mm size.
Old 04-06-2003, 08:01 PM
Nikon!!!
thaiphob's Avatar
Default Re: oil filter wrench size (envious1320)
just drink some powerade and use your hands
Old 04-06-2003, 08:09 PM
B2FiNiTY's Avatar
Easiest way would be to bring the filter into a car store and try them all
Old 04-06-2003, 08:18 PM
Default Re: oil filter wrench size (B2FiNiTY)
the filter is on my car and i cant get it off i had acura first do it when i first bought the car and the used a wrench and tighened it too tight now i need a wrench and dont know what size. I tired one of those clinch kind and broke it.
Old 04-06-2003, 09:00 PM
mamaboy's Avatar
go to autozone or pepboys and get yourself one of those mechanix gloves. I won't do anything without them. If you find it hard to grasp the filter without slipping try those and work it. These gloves are great
Old 04-06-2003, 09:04 PM
andrewM's Avatar
go to the store, find the right filter, then try out all the wrenches on that one. it should be the same size.
Old 04-06-2003, 10:57 PM
Loveless's Avatar
Default Re: oil filter wrench size (andrewM)
they don't come with the service bolt.
just do it like this, if a 150lb asian can do it with bare hands, you can too
Old 04-06-2003, 11:10 PM
brinks's Avatar
Easier way would be to pick up a replacment filter off the shelf and see what wrench fits it.
Old 04-06-2003, 11:25 PM
tC_Dragon's Avatar
Default Re: oil filter wrench size (brinks)
get this instead of the standard oil filter wrench.. you can pretyt much use it for 99% of oil filter sizes... plus it werks alot better.
Its made by craftsman and can be purchased at ur local sears
Old 04-06-2003, 11:45 PM
Loveless's Avatar
Default Re: oil filter wrench size (pdcdragon)
is that a speciality tool? how much is it? I just used 2 wrenchs and they worked well that way.
Old 04-06-2003, 11:58 PM
tC_Dragon's Avatar
Default Re: oil filter wrench size (Loveless)
it is made for use on oil filters.. i think they jus call it an oil filter wrench and it werks wit a 3/8" drive ratchet so that the more u turn the tighter grip u have on it.. so it won't slip.. seriously tho.. you won't ever complain about having a hard time wit filters after u get that... and as for cost i think it was around 15 maybe a lill less
Old 04-07-2003, 07:29 AM
Eva01's Avatar
Sometimes if the filter is good and stuck I'll use a piece of sandpaper to get a good grip it and really just crank on it and that gets it loose. Looks like you can also order a filter wrench from acuraautomotiveparts.org as well:
No. 10
gemineye716
09-24-2008 05:29 PM
99fbpem1
12
09-11-2007 02:15 PM
navin
01-10-2007 07:41 PM
BuyImports2
03-28-2005 06:05 AM
Flux
03-24-2002 07:43 PM
Quick Reply: oil filter wrench size
