obd2 gsr motor with NO VIN NUMBER/TAG on the block :( ???? what should I do?
Is there some other way of telling if the motor if stolen besides going off the vin... since this block doesnt have the vin tag attached? where it says B18c1, under that has a few numbers.... can I call the local pd and read those numbers to them to see if its legit? any info would help. Thanks
dont know if they took it off or it fell off but has the rivet holes for the vin tag.
where would the vin be located on the tranny? I just see a bar code with y80 starting and some other numbers next to it.
Re: obd2 gsr motor with NO VIN NUMBER/TAG on the block :( ???? what should I do? (Kangolbrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand »</TD></TR><TR><TD CLASS="quote">Is there some other way of telling if the motor if stolen besides going off the vin... since this block doesnt have the vin tag attached? where it says B18c1, under that has a few numbers.... can I call the local pd and read those numbers to them to see if its legit? any info would help. Thanks
dont know if they took it off or it fell off but has the rivet holes for the vin tag.</TD></TR></TABLE> The numbers under the B18C1 is the production number and means nothing! I've had a jdm gsr that did'nt come with any vins. And the ref is only concerned if the car passes smog or not and if it is done correctly, I'm sure he is not interested in turning his customer's in!
Kangolbrand
58
07-20-2006 10:35 AM
migs
09-24-2002 04:31 AM
ric3 daddie
01-22-2002 10:00 AM
