obd2 diagram needed
Old 06-20-2005, 09:08 AM
dc4drewH's Avatar
Default obd2 diagram needed
sup, well heres the deal I am going to be hard wiring a couple plugs and i was looking for a obd2A ecu diagram for A,B,and D plugs with all pin numbers and names. I have been searching for an hour and everything that comes up is either red X's or obd1 stuff. I have also tried other forums so all i need is maybe an email or a link of some sort thanks. help is appreciated
Old 06-20-2005, 11:09 AM
IN VTEC's Avatar
Default Re: obd2 diagram needed (dc4drewH)
I can give you a few pics from my '98 manual of the ECU sockets.
What sensors and/or actuators are you wiring? You might find it useful if I gave you some of the electrical connection pages so you can look up where it junctions and pin everything to a socket instead of running the wires by themselves. That way it'll also give you an easy way to disconnect the wires any time you have to pull the motor or whatnot.
Old 06-20-2005, 01:21 PM
97tegGS's Avatar
Here you go. I believe this is what your looking for. I used my car 97 w. b18B1
Old 06-20-2005, 02:40 PM
dc4drewH's Avatar
Default Re: obd2 diagram needed (97tegGS)
bowdown!!^^^
thanks guys, Now it is time to hardwire some things. Being that i have no vtec and i am a P30 and currently on throwing 1 CEL which is 23 (knock). So i have heard that it affects timing and vtec will not engage if throwing that cel. correct?
Old 06-20-2005, 03:04 PM
97tegGS's Avatar
Correct. It would run in what I would call "Safe Mode"
Old 06-20-2005, 03:52 PM
dc4drewH's Avatar
Default Re: (97tegGS)
or limp mode
update: the teg is cel-less but currently blocked in so no test drive yet but crossing fingers and hoping for the best..
Old 07-12-2005, 10:46 AM
tofu__'s Avatar
this is the same pinouts for the p72 also?
Old 07-12-2005, 06:18 PM
dc4drewH's Avatar
Default Re: obd2 diagram needed (tofumonzter)
as long as its obd2a
Old 07-12-2005, 06:21 PM
internetautomart's Avatar
to be specific the detection of a knock or a faulty knock sensor will cause the timing to be retarded because knock is assuned to be caused bt pre-ignition
Old 07-02-2007, 05:38 AM
turbo gsr
Guest
Posts: n/a
does anyone happen to have this pinout for a 94 gsr obd1?
Old 07-02-2007, 04:34 PM
turbo gsr
Guest
Posts: n/a
Default Re: obd2 diagram needed (turbo gsr)
ttt
Old 07-03-2007, 11:01 AM
crxgator's Avatar
^ dont buy anything from this kid...
Old 10-15-2007, 10:02 AM
98dc23's Avatar
so if the knock sensor is not detected would it cause the motor to knock?
Old 10-15-2007, 12:39 PM
dizzzane's Avatar
Default Re: obd2 diagram needed (98dc23)
It won't cause the motor to knock. If the sensor isn't there though, the ecu will think it is knocking and will throw the ecu into limp mode.
Old 09-06-2009, 11:38 PM
bigwalt707's Avatar
Icon3 Re: obd2 diagram needed
hey i did a 99 si swap in my 97 ex used the wire harness but it dont plug into my 99 si ecu cuz its OBD2B and my harness is OBD2A does any one know how i can re pin it to use the Si ecu,i already got the B connector plug and just need to switch pins around so can any one help??
Knock sensor doesn't make ur engine knock it detects knock EXAMPLE..if u ran ur Engine with no oil and u damage it then the knock in the Engine changes so that will cause it to throw..it sends the signal to the ecm around i think its 5v and when the knock in the Engine changes, for any reason it will throw the Check engine light... its self producing voltage from the move meant of the Engine that's how it works...When ur engine is running fine it keeps the same amount volts sent to the ecm. correct me if im wrong..
Old 02-20-2013, 05:24 PM
Terrymiller's Avatar
props to the original writer of this thread! helped lots
Old 01-22-2017, 01:35 PM
darksid3honda's Avatar
anyone know why my obd2 scan plug will not let the scan tool connect to read a check engine light I swapped in a itr ecm which is obd2a same as my old p75
Old 01-27-2017, 05:39 AM
Fish Twig
tony_2018's Avatar
pics of ecu part #.
jerr
10-26-2008 11:32 AM
PliggityPB
02-17-2003 10:20 PM
hybridb18
02-01-2003 09:30 PM
Quick Reply: obd2 diagram needed
