New pads/rotors squeeling???
Old 03-09-2009, 02:34 PM
BoltonGSR's Avatar
Default New pads/rotors squeeling???
I got myself some axxis ultimate pads and autozone rotors. When i first installed them last month I forgot to hit the rotors with brakes cleaner which then caused juttering when stopping.
Since then I took off the rotors cut them just a little and sanded the pads down real good to remove the gunk. Now my front right wheel is making the sound that pads do when they are on the wear indicator. It happens with no brake pressure at all... wtf?
Or is this normal for these pads, cause ive read some posts that would indicate that...
Old 03-09-2009, 02:47 PM
B16aRS5's Avatar
Default Re: New pads/rotors squeeling???
Sometimes they will squeak because there is dust on them. Did u put the little sqeak plate things back on?
Old 03-09-2009, 02:59 PM
TicketTom's Avatar
tear it apart and clean everything then get a product from napa called silglye and apply it any where where the pad touches the caliper and where the caliper bolts on to the hub that should get rid of the squeel its also good for belts and conditioning rubber seals
Old 03-09-2009, 05:44 PM
BoltonGSR's Avatar
I did blow the lower ball joint on that side of the axle but I dont think that is causing this. I dont think its the anti squeel cause I applied it. It makes the same sound as when the wear indicator is getting hit by the rotor.
Old 03-09-2009, 06:00 PM
TunerN00b's Avatar
Did you bed the new pads correctly?
Old 03-09-2009, 06:48 PM
BoltonGSR's Avatar
Yes, 8 stops from 60 to 10 then 4 from 80 to 10 (performance pads only)
Old 03-10-2009, 07:30 AM
TicketTom's Avatar
well i had the same problem with my wilwood brake kit and it just ended up being me using crappy anti squeen since i have started using silglye i havent had the problem anymore
H2290
10
07-28-2006 01:56 PM
kornerk12
04-27-2006 01:17 PM
LudeyKrus
06-10-2003 03:40 PM
6ghatch
06-16-2002 05:53 PM
Quick Reply: New pads/rotors squeeling???
